Re: disc brake spindle question - b body
[Re: 340duster340]
#183067
01/03/09 10:25 PM
01/03/09 10:25 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Sounds like you already have a good set of spindles. All the parts for the 73-74 Charger should work great for you. These spindles are slightly taller but there's no issue with using them in your application. Just make sure you use a matching master cylinder (for disk brakes) and an adjustable proportioning valve in the rear brake line.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#183068
01/03/09 10:51 PM
01/03/09 10:51 PM
Posts: 4,323 NY NY
340duster340
NY NY
thanks, a few other quick questions:
can someone school me on the a vs. b vs. e body spindle?
are all b spindles the same? and can a/e interchange with b?
also what years are in play here?
thanks!
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#183069
01/03/09 10:58 PM
01/03/09 10:58 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
70/2 B/E spindles and brakes are the same. 73/4 B are different. Taller spindle, larger bearings and different caliper mounting. 73/4 E spindles are the same as 70/2 but have larger bearings. A body have shorter spindles than B and E.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#183070
01/03/09 11:05 PM
01/03/09 11:05 PM
Posts: 1,978 USA
Suregrip391
USA
When you say " 73/4 B are different. Taller spindle, larger bearings and different caliper mounting" are you referring to slider vs. pin type caliper mount?
[Re: DoctorDiff]
#183075
01/03/09 11:16 PM
01/03/09 11:16 PM
moparmarks
Caliper mount holes are the same on all knuckles. The (tall) knuckles are just swapped left to right on the newer B,F,M,J,R bodies.
So you can just swap sides to have rear mount calipers?
[Re: hemi71x]
#183079
01/04/09 01:25 PM
01/04/09 01:25 PM
Posts: 1,978 USA
Suregrip391
USA
The 73 spindles are "Taller" if they are from a B body car.
If you use a taller spindle, does it effect wheel size, 14" or 15" or does that only come into play when deciding which size rotor you want to use?
[Re: Suregrip391]
#183081
01/04/09 03:07 PM
01/04/09 03:07 PM
Posts: 5,363 Rancho Cordova, California (Sa...
hemi71x
You need to use 15 inch wheels if you use the 11 3/4 inch diameter rotors. Then you would need the larger caliper mounts from the later 70's Cordobas, Magnums, St. Regis, Furys,Chargers, whether they are the pin type, or slider type. Just depends on what type of caliper that you want to use.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: John_Kunkel]
#183083
01/04/09 10:23 PM
01/04/09 10:23 PM
Posts: 3,379 KY USA
mopargem
KY USA
So who do we believe on the 73 up B body spindles, I have heard they can be dangerous with an earlier car swap.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#183084
01/05/09 12:36 AM
01/05/09 12:36 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
I’m going with Richard Ehrenberg’s opinion which is dead set against using the taller spindles on pre-73 B-bodies. Some say it is not necessary, but I rather error on the side of factory suspension geometry than not.
Remember, this is Richard Ehrenberg of the “Green Brick” fame. He knows how to set up a Mopar suspension for performance.
Read more at this Mopar Action Tech article:Disc-O-Tech
[Re: mopargem]
#183085
01/05/09 02:50 AM
01/05/09 02:50 AM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
73 up F,M,J and B are fine for the swap. Where did you "hear" it was dangerous? Have you ever actually known of someone having issues with the swap? I havent and neither has anyone I know who has done it or knows someone else who has. You'd think if it was such a dangerous thing it would be well documented with accident reports and such, but its not. Go figure I'm working on another brake swap in the shop now, a 74 Satellite disc set-up installed on a 72 Demon
