Re: And so it begins.... The elephant swap.
[Re: MoparJunkie]
#1786302
03/24/15 02:02 PM
03/24/15 02:02 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Good luck Greg.... It'll be nice when done. I just finished my install of a 426 Hemi into my Daytona... Have fun.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1786303
03/24/15 02:08 PM
03/24/15 02:08 PM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
Thanks Troy... Gonna need it! Lol. I think the big stuff is done, but there are some fine adjustments left to do... Lol
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: MoparJunkie]
#1786305
03/24/15 03:43 PM
03/24/15 03:43 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
That elephant looks good in there!
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: MoparJunkie]
#1786311
03/26/15 06:21 PM
03/26/15 06:21 PM
Posts: 4,179 California
mickm
California
looking at your throttle cable linkage, depending on the setup on the carb itself, you may need to modify the bracket that holds the throttle cable. to get the correct geometry, i ended up taking that stock (repop) bracket and cutting it and inserting a 1" or so piece to raise the hold down higher up.
I had noticed that the cable was going to be tight and bound up. Hadn't really given it much more thought til you said this.... Guess I'll see what happens????
After further investigation... It's gonna work just fine.
[Re: mickm]
#1786312
04/03/15 09:21 AM
04/03/15 09:21 AM
MoparJunkie
Just a quick update.... My Passon overdrive 4 speed has been shipped, so I should know very soon how these mounts are gonna line everything up...Or not?!?!?!?!?!?!?! Lol Also, I had to swap out the cast valve covers. They were WAY too close to passenger shock tower, so i went with a set of stock repops. My Glen-Ray 956 radiator came in, and it's very NICE. I'll post pics this weekend of progress so far.
[Re: MoparJunkie]
#1818706
05/04/15 07:06 PM
05/04/15 07:06 PM
MoparJunkie
Well, I've made her road worthy.... Just have to get the A/F issues figured out. Thanks to Sheldon for the ballpark setup on jets and metering rods. Just have to get those dialed in. I have some light load, and part throttle lean stumbling issues. Gonna go with stiffer springs and smaller metering rods to try and cure the lean conditions. Timing is at 18* initial and 14* mechanical all in by 3100 RPM to prevent pinging on the street... Wish me luck Again, this is my first hemi experience....
[Re: MoparJunkie]
#1818995
05/04/15 11:59 PM
05/04/15 11:59 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Glad to hear it's running, it sounds lean all right. What colour top is on this car? I was looking at an FJ5, 4 speed U-code RT/SE near me a week ago that I was tempted to Hemi-up it had white roof and stripes, kind of a coincidence.
Sheldon
Sheldon
