And so it begins.... The elephant swap. #1786301
03/23/15 12:06 AM
03/23/15 12:06 AM
Home of the Bluegrass
MoparJunkie Offline OP
Hey guys it's been a while. I reacquired my old green 70 Challenger with a shaker hood, 505 stroker, 4 speed, and a DANA 60. I've started the swap to the 472 hemi that Stanton Racing put together for me. I'm using Scumacher mounts and TTI 2 1/8" headers, so we'll see how this goes???? Looks like it's gonna be tight with the MP cast aluminum valve covers...Particularly on the passenger side shock tower and blower motor. Tune in til I get the trans bolted back in to see how the fitment shakes out... Especially with the shaker hood!!!
Here's some pics of the install process...
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1786302
03/24/15 02:02 PM
03/24/15 02:02 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Good luck Greg.... It'll be nice when done. I just finished my install of a 426 Hemi into my Daytona...
Have fun.
Troy
Houston Mopar Connection Club
Re: And so it begins.... The elephant swap. [Re: hemi68charger] #1786303
03/24/15 02:08 PM
03/24/15 02:08 PM
Thanks Troy... Gonna need it! Lol. I think the big stuff is done, but there are some fine adjustments left to do... Lol
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1786304
03/24/15 02:54 PM
03/24/15 02:54 PM
California
mickm Offline
mickm  Offline
California
looking at your throttle cable linkage, depending on the setup on the carb itself, you may need to modify the bracket that holds the throttle cable. to get the correct geometry, i ended up taking that stock (repop) bracket and cutting it and inserting a 1" or so piece to raise the hold down higher up.
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1786305
03/24/15 03:43 PM
03/24/15 03:43 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
That elephant looks good in there!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: And so it begins.... The elephant swap. [Re: mickm] #1786306
03/25/15 12:13 AM
03/25/15 12:13 AM
I had noticed that the cable was going to be tight and bound up. Hadn't really given it much more thought til you said this.... Guess I'll see what happens????
Re: And so it begins.... The elephant swap. [Re: OhioMopar] #1786307
03/25/15 12:14 AM
03/25/15 12:14 AM
I thought so too!
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1786308
03/25/15 02:45 AM
03/25/15 02:45 AM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
Looking good!
On your carb return springs, the red is for the rear carb and the green is for the front carb. The rear spring attaches to the lower hole in the bracket, the upper hole is for the kickdown linkage return spring on the auto cars.
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1786309
03/25/15 04:05 PM
03/25/15 04:05 PM
After further investigation... It's gonna work just fine.
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1786310
03/25/15 10:37 PM
03/25/15 10:37 PM
motor city
sixty9redgtx Offline
motor city
That HEMI looks sweet!
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1786311
03/26/15 06:21 PM
03/26/15 06:21 PM
California
mickm Offline
mickm  Offline
California
Re: And so it begins.... The elephant swap. [Re: mickm] #1786312
04/03/15 09:21 AM
04/03/15 09:21 AM
Just a quick update.... My Passon overdrive 4 speed has been shipped, so I should know very soon how these mounts are gonna line everything up...Or not?!?!?!?!?!?!?! Lol
Also, I had to swap out the cast valve covers. They were WAY too close to passenger shock tower, so i went with a set of stock repops. My Glen-Ray 956 radiator came in, and it's very NICE. I'll post pics this weekend of progress so far.
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1798129
04/08/15 12:21 AM
04/08/15 12:21 AM
Okay, let's try this again(thanks to the upgrade)... I have everything installed and.... The engine sits up maybe 1/2" at the most. I used a 4 ft level and this thing is spot on with the Schumacher mounts! I am very pleased with the results. The fan sits in the shroud great, but like I said they raised everything about a 1/2". Still haven't installed the shaker bubble but I've done some eyeballing and it's gonna be close. Some minor tinkering and it's off we go.... drive
Try to get more pics soon!
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1804219
04/15/15 03:27 PM
04/15/15 03:27 PM
Getting closer...
Really pleased with the fitment of everything. Really like the firecore wires Rick Gorski set me up with too!!! up
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1818706
05/04/15 07:06 PM
05/04/15 07:06 PM
Well, I've made her road worthy.... Just have to get the A/F issues figured out. Thanks to Sheldon for the ballpark setup on jets and metering rods. Just have to get those dialed in. I have some light load, and part throttle lean stumbling issues. Gonna go with stiffer springs and smaller metering rods to try and cure the lean conditions. Timing is at 18* initial and 14* mechanical all in by 3100 RPM to prevent pinging on the street... Wish me luck up
Again, this is my first hemi experience....
Re: And so it begins.... The elephant swap. [Re: MoparJunkie] #1818995
05/04/15 11:59 PM
05/04/15 11:59 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Glad to hear it's running, it sounds lean all right. What colour top is on this car? I was looking at an FJ5, 4 speed U-code RT/SE near me a week ago that I was tempted to Hemi-up it had white roof and stripes, kind of a coincidence.
Sheldon
Sheldon
Re: And so it begins.... The elephant swap. [Re: RUNCHARGER] #1819029
05/05/15 12:22 AM
05/05/15 12:22 AM
Sheldon, it is in fact white top and stripe... That is weird, however that seems to be a popular combination. whistling
