Re: How do you route ministarter wires around headers?
[Re: BigAg]
#1817481
05/03/15 02:44 AM
05/03/15 02:44 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Did you end up making your own cables or did you buy one that went the whole way? No... Used an OEM cable... Later, and a little shorter than a stock '71 B cable...
[Re: RSNOMO]
#1817511
05/03/15 04:18 AM
05/03/15 04:18 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I used a new mini starter when I put a new 440 in my '64 Polara. As I recall, I had to change the connector on the starter and I installed the wires that I made up and then hung the starter. I used a protective silicone sleeve over the wires to protect them. It was called "Firesleeve" and used some of the same stuff to protect the push button shifter cable. I found it at an industrial supply house. Good stuff.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: BigAg]
#1818097
05/03/15 11:28 PM
05/03/15 11:28 PM
Posts: 1,800 South Lyon MI
sleddinfool
South Lyon MI
I did this and put a dei sleeve around the cable. I used the original cable. You can see it between the second and third header tube and then going up on top of the engine.. Kevin
71 gtx.....
[Re: BigAg]
#1818099
05/03/15 11:30 PM
05/03/15 11:30 PM
sleddinfool
South Lyon MI
Wrong pic, lol, try this one. Kevin
71 gtx.....
