How do you route ministarter wires around headers? #1817111
05/02/15 03:37 PM
05/02/15 03:37 PM
BigAg Offline OP
BigAg  Offline OP
I have a 71 charger with a 440 engine in it. I have headers on the engine and as such have a mancini mini starter with it. I have trying to figure out how to hook the cables from the battery to the mini starter terminals. The stock cables that i bought don't seem to reach if I go around the headers. How did those that have done something similar to this get the cables to get reach the starter terminals? Right now I am thinking maybe i need to solder some length to cables and then attached them to the front firewall and then over to the ministarter.
Re: How do you route ministarter wires around headers? [Re: BigAg] #1817174
05/02/15 05:29 PM
05/02/15 05:29 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'71 Ply with a 440, and Hooker's...
Fabbed-up a bracket to support the cable(s) going to the starter...
Re: How do you route ministarter wires around headers? [Re: RSNOMO] #1817228
05/02/15 06:25 PM
05/02/15 06:25 PM
BigAg Offline OP
BigAg  Offline OP
Did you end up making your own cables or did you buy one that went the whole way?
Re: How do you route ministarter wires around headers? [Re: BigAg] #1817287
05/02/15 08:09 PM
05/02/15 08:09 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The Hemi cars had a hanger bracket that bolted to the back of the head.
Re: How do you route ministarter wires around headers? [Re: BigAg] #1817481
05/03/15 02:44 AM
05/03/15 02:44 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
No...
Used an OEM cable...
Later, and a little shorter than a stock '71 B cable...
Re: How do you route ministarter wires around headers? [Re: RSNOMO] #1817511
05/03/15 04:18 AM
05/03/15 04:18 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I used a new mini starter when I put a new 440 in my '64 Polara. As I recall, I had to change the connector on the starter and I installed the wires that I made up and then hung the starter. I used a protective silicone sleeve over the wires to protect them. It was called "Firesleeve" and used some of the same stuff to protect the push button shifter cable. I found it at an industrial supply house. Good stuff.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: How do you route ministarter wires around headers? [Re: BigAg] #1817871
05/03/15 06:57 PM
05/03/15 06:57 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I had to get a set of cables made to get the "slack" I wanted to keep away from the headers. I had somebody make me a set that was 6" longer (starter leads) than OEM and it works fine on my 73 Charger.
I used to the factory bracket that held the cables on the frame rail. I just needed the extra length as the terminals on the starter where on the "inside" of the starter (against the block) which necessitated the extra length.
Re: How do you route ministarter wires around headers? [Re: BigAg] #1818097
05/03/15 11:28 PM
05/03/15 11:28 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
I did this and put a dei sleeve around the cable. I used the original cable. You can see it between the second and third header tube and then going up on top of the engine.. Kevin
71 gtx.....
Re: How do you route ministarter wires around headers? [Re: BigAg] #1818099
05/03/15 11:30 PM
05/03/15 11:30 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
Wrong pic, lol, try this one. Kevin
71 gtx.....
Re: How do you route ministarter wires around headers? [Re: Polarapete] #1818835
05/04/15 09:20 PM
05/04/15 09:20 PM
Third rock from the sun.
busboy Offline
busboy  Offline
I did exactly the same as polar a Pete for the 340 in my a-body. Made up my own set, a tad longer from what I remember, with the right terminals for the mini starter then slipped some asbestos heat tubing over it for a little heat protection from the headers. 6 years, no problems up
Oh yeah, it's a hybrid.....it burns gas and tires!
