Page 1 of 3 1 2 3
650 HP street car????? #181435
01/02/09 12:42 PM
01/02/09 12:42 PM
London,Ontario,Canada
1962Savoy Offline OP
OK heres what I would like to do, or have done by an expert!
Ultimately I would like to have a 650 hp street car that will run on pump gas and I can have fun at the track few time a year. I dont want something I'm going to have to turn a wrench on every weekend just a good solid built motor. Is this too much to ask????
I would like to start with a 400 R block and have it stroked to 511???
What I need from you guys is your opinions on what internals I need for a strong ,good build from top to bottom!
I really need my 62 Savoy to rock and kick Chebby A$$'s
I'm having a midlife crisis
Re: 650 HP street car????? [Re: 1962Savoy] #181436
01/02/09 12:50 PM
01/02/09 12:50 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
You are into the territory where you need to talk with someone like DRAM. Your HP requirements are close to what mine are for the Superbee. You will be looking at forged crank, Manley H rods, Diamond pistons and a basic stroker setup. I believe he is setting my engine up for about 10.75-1 compression running E-heads so it will run on pump gas. On the top end I am going with a roller hydraulic setup. The engine has not been dyno'd yet but DRAM's best guess is 630 engine HP. You can go more but things start to get a lot pricier and engine life is affected. Look to spend about 10k+ for this type of setup.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: 650 HP street car????? [Re: 1962Savoy] #181437
01/02/09 12:59 PM
01/02/09 12:59 PM
AndyF Offline
AndyF  Offline
It is easy to make 650 hp, the hard part is doing it in a combination that doesn't require much maintenance. A hyd roller cam is probably the way to go for low maint, but you'll pay a price in terms of power output.
A low deck 512 with CNC ported std port heads (Edelbrock, Mopar Performnce 452, etc) will get you close to 650 hp with the right cam and compression but the motor is a balancing act. Give the guys at Best Machine in MI a call, they can build you what you need.
Re: 650 HP street car????? [Re: 1962Savoy] #181438
01/02/09 02:13 PM
01/02/09 02:13 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Just a though, but how many tanks of gas are you going to burn through this thing a month? Maybe one? For about $32 to $40 more a month, you can run a high quench, 12.5 or 13 to 1 compression motor. That's about a buck a day to add 4 or 5 gallons of race fuel to a tank of unleaded pump gas. Works for me with 680 hp in a low maintenance 493" sixpack motor that doesn't need to rev past 5500 rpm to do it.
There's nothing like high compression in a big block Mopar, especially in a stroker.
Re: 650 HP street car????? [Re: klunick] #181439
01/02/09 03:12 PM
01/02/09 03:12 PM
Who is DRAM???
I know 10G's+ is were I will be and I dont really mine turning a wrench when needed. I was just trying to get a low maintanace motor and to see what others are using
Re: 650 HP street car????? [Re: AndyF] #181440
01/02/09 03:22 PM
01/02/09 03:22 PM
Thanks Andy!
I have been in touch with Best but they must be busy I asked Chuck for some info but havent received anything yet. I defintaly want to go with a rollewr cam and I think a bottom end girdle as well just to be on the safe side of things.
If you had to build one what would you use????
Re: 650 HP street car????? [Re: 1962Savoy] #181441
01/02/09 04:04 PM
01/02/09 04:04 PM
Holland MI Ottawa
2
2boltmain Online content
2boltmain  Online Content
Holland MI Ottawa
Hey 1962savoy-is your avatar thingie Mr Bean?????He is awsome!
Keep old mopars alive.
Re: 650 HP street car????? [Re: 1962Savoy] #181442
01/02/09 04:27 PM
01/02/09 04:27 PM
AndyF Offline
AndyF  Offline
Pick up a March 2009 Mopar Muscle magazine. I wrote an article in there on my 505 motor which is probably pretty close to what you're looking for. That motor had a Comp street roller camshaft, Super Victor intake, CNC ported heads from Mancini Racing, etc. It made 680 hp but the cam and the carb would both be a little too big for what you want. If you dial the cam back a few notches and put a smaller carb on there you'll probably hit your number and still be somewhat streetable.
Re: 650 HP street car????? [Re: 1962Savoy] #181443
01/02/09 04:37 PM
01/02/09 04:37 PM
Brunswick Ohio
dusta340 Offline
dusta340  Offline
Brunswick Ohio
call Nick at Compuflow 330-725-7591
tell him Rick Said to hook him up and he will take care of you
Re: 650 HP street car????? [Re: AndyF] #181444
01/02/09 04:44 PM
01/02/09 04:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hmmmm ... one stop shopping ...
1300.00 for a fully machined 440SOURCE block
2000.00 for the stroker kit with upgraded rods and bearings
2000.00 for a set of their CNC'd heads
other misc. pieces.
About the only thing they don't have are hyd. roller cams, intakes and carbs. Trade compression and crazy cam profiles for cubic inches and NEVER have a problem with pump gas.
I think it'd be easier to achieve your HP goal and wouldn't cost any more to do if you went with a 543 stroker kit in a 440.
Re: 650 HP street car????? [Re: 1962Savoy] #181445
01/02/09 05:47 PM
01/02/09 05:47 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
PM me. I did a 493 that made 630HP/652 torque with E heads and it ran 10.81 in a street/strip 74 Charger.
Re: 650 HP street car????? [Re: torkrules] #181446
01/02/09 06:21 PM
01/02/09 06:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Nice combo! Can you post the details of the build?
Re: 650 HP street car????? [Re: DaytonaTurbo] #181447
01/02/09 09:05 PM
01/02/09 09:05 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Here's my 517 (4.375" bore B motor, 4.30" stroke)...it's got some pretty killer heads and a hydraulic roller but I can assure you it's perfectly streetable at the 700hp range. I cruise in traffic all the time, never runs hot, never loads up, razor sharp throttle response and great street manners are 100% required whenever I do a motor.
http://www.youtube.com/watch?v=jd8GeXYYkKU&feature=channel_page
so 650 is perfectly doable....so long as you build from a solid foundation of a wise selection of parts, excellent machine work and careful assembly. (A top notch cooling system is a must too for those days when you get caught in a summer traffic jam). With the right cam, compression inductio nad stall/gearing it can be perfectly docile and tractible in street traffic....but whenever you nail it....all will break loose!!
WIZE
In Car:
Re: 650 HP street car????? [Re: Streetwize] #181448
01/02/09 10:31 PM
01/02/09 10:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
How fast do you want to go if you dont mind me asking ? I only ask because my very mild 440 is putting out around 500 flywheel hp and runs mid 11's at 3700 lbs. If I had 650 HP with the right torque I feel I could run mid 10's. What I mean is a nice 650 hp stroker should push your 62 to easy mid 10's with a decent suspension and the right gear. Ron
Re: 650 HP street car????? [Re: Streetwize] #181449
01/02/09 10:48 PM
01/02/09 10:48 PM
None
71rm23 Offline
71rm23  Offline
None
Streetwize, that is SWEEET!!! I'd like 550HP at least
Re: 650 HP street car????? [Re: DaytonaTurbo] #181450
01/03/09 11:40 AM
01/03/09 11:40 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Certainly. It's been a few years, but here goes:
Mega Block (4.375 bore X 4.15 stroke)
E-Heads (performers). with back cut valves and mild clean up of ports
Ross flat top pistons (block decked for zero deck height) 11.2:1 compression
Comp cams .650 lift mechanical roller (off the shelf piece). Only maintenance was valve springs after 3 years of running and checking lifters.
Eagle H-beam rods
Victor intake with welded and blended 4500 adaptor
Holly 1050 list 8896-2
2" X 3.5" headers
Re: 650 HP street car????? [Re: 383man] #181451
01/04/09 05:57 PM
01/04/09 05:57 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I'm with Ron with this. I'm always curious when a guy wants XXX hp.
You can get to 650 hp different ways. But how you get there will be somewhat dependent on your "steetable" criteria and level of wrench turning that you are willing to do.
Re: 650 HP street car????? [Re: BSB67] #181452
01/04/09 09:14 PM
01/04/09 09:14 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
be carefull what you wish for. yes, you can build a maintence free 511 that makes 650hp. but is the rest of the car up to the task? you may not be turning wrenches on the engine but i assure you that you will be turning them somewhere. if your car isnt ready, you will be disappointed in its performance and have your butt handed to you be a chevy making 400 hp
Re: 650 HP street car????? [Re: sixpackgut] #181453
01/04/09 09:23 PM
01/04/09 09:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yup. A well set-up car can really make the difference.What does your '62 have done to it, to make sure that +600hp isn't going to take and put your drive shaft into orbit and hurt the heck out of the floor boards?
Re: 650 HP street car????? [Re: Dragula] #181454
01/04/09 10:32 PM
01/04/09 10:32 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I can't describe the reaction I felt from Wize's video on a family site....anyway... I would do anything for a motor like that..... But your point on the whole car working is close to me in that I watch a local guy here with a very simply built very clean Duster with a 360 that just put's it on guy after guy with their radical HP motors. But the thing leaves like a rocket, doesn't spin, doesn't break, He shuts it off, doesn't touch it for a week, gets in it and does it again. It just plain makes a lot of those guys upset, Chevy, Ford or Mopar. He does it all the time......That being said......I'm gonna go watch Wize's vid again and check to see how much room I have on my credit card......
Page 1 of 3 1 2 3
