Re: Digital multimeter recommendations please
[Re: A990]
#1812713
04/27/15 12:00 AM
04/27/15 12:00 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Fluke is an excellent brand, if you are checking capacitors, an old analog one will probably work good for that task but I have a fluke 77 and a 119. I bought my first fluke in a pawn shop and sent it to fluke for repair, had almost 100 invested before I learned to check each setting before buying used. Now I try to buy new. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: A990]
#1812725
04/27/15 12:07 AM
04/27/15 12:07 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Let me see if I have this straight
Fluke repairs what it sells? Repair and calibrate from memory, yep.
[Re: A990]
#1812726
04/27/15 12:08 AM
04/27/15 12:08 AM
OzHemi
Garden Grove, CA
why am I not shocked at all this If you had a meter, you could tell just how shocked you were.
[Re: OzHemi]
#1812733
04/27/15 12:15 AM
04/27/15 12:15 AM
Posts: 2,735 541 slobovia
A990
541 slobovia
why am I not shocked at all this If you had a meter, you could tell just how shocked you were. I'm still unphased
[Re: A990]
#1812752
04/27/15 12:25 AM
04/27/15 12:25 AM
OzHemi
Garden Grove, CA
why am I not shocked at all this If you had a meter, you could tell just how shocked you were. I'm still unphased There is a meter for that too.
[Re: astjp2]
#1812759
04/27/15 12:32 AM
04/27/15 12:32 AM
OzHemi
Garden Grove, CA
Fluke is an excellent brand, if you are checking capacitors, an old analog one will probably work good for that task but I have a fluke 77 and a 119. I bought my first fluke in a pawn shop and sent it to fluke for repair, had almost 100 invested before I learned to check each setting before buying used. Now I try to buy new. Tim The capacitance setting on the newer meters are nice..
[Re: E-Ticket]
#1812788
04/27/15 12:55 AM
04/27/15 12:55 AM
A990
541 slobovia
"Fluke".....there is no room inaccurate readings that could cause you to chase your tail and accuracy starts with quality tooling.....:)..... OK Welll I guess I'm sold on that 77-4
[Re: A990]
#1812790
04/27/15 12:56 AM
04/27/15 12:56 AM
Posts: 114 Oregon
Wagonman1967
I have a Fluke 87-3 that I had to buy to test for parasitic draws 30Ma was the spec. i also use my old Snap-on Mt836 for testing Alt diodes and rectifier bridges. The old analogue meters still have their place. Thank God I dont have to use these to make a living anymore.
1968 Bronze Metalic Road Runner !967 Malibu Wagon Original 4sd w/air 2001 Dodge Ram 4wd 1985 GMC K1500 4in lift 1993 Honda Civic W 350k Beater 2003 Honda VTX 1800 Bagger
[Re: A990]
#1812811
04/27/15 01:21 AM
04/27/15 01:21 AM
OzHemi
Garden Grove, CA
"Fluke".....there is no room inaccurate readings that could cause you to chase your tail and accuracy starts with quality tooling.....:)..... OK Welll I guess I'm sold on that 77-4 Electrifying decision
