5.9 Magnum rod bearing question? #180606
01/01/09 05:21 PM
01/01/09 05:21 PM
Southwestern Ontario Canada
racealittle Offline OP
I pulled a rod bearing to inspect from a 1999 RT motor. The marking says "12 98 D, DA 49"
So how do I read this to determine what the bearing size is? Would Clevite 77's from Mancini be adequate replacement? I don't like the look of the bearing and thirty some dollars for a set are cheap insurance.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: 5.9 Magnum rod bearing question? [Re: racealittle] #180607
01/01/09 05:30 PM
01/01/09 05:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
mike the rod journal to find out the size...
12 98...date of manufacture for the bearing...which fits a 99 engine..
u should see on the other end of the bearing...
std..for standard ...or .010..of undersize journal
Tony
70 AARCuda Vitamin C
Re: 5.9 Magnum rod bearing question? [Re: 70AARcuda] #180608
01/01/09 05:39 PM
01/01/09 05:39 PM
There are no other markings.
Re: 5.9 Magnum rod bearing question? [Re: racealittle] #180609
01/01/09 05:40 PM
01/01/09 05:40 PM
Some pics
Re: 5.9 Magnum rod bearing question? [Re: racealittle] #180610
01/01/09 05:41 PM
01/01/09 05:41 PM
Another
Re: 5.9 Magnum rod bearing question? [Re: racealittle] #180611
01/01/09 06:00 PM
01/01/09 06:00 PM
The lower portion of the shell is marked "12 98 C" No other markings. I don't have a mic large enough to measure the journal. I have never seen a bearing without a size on it.
Re: 5.9 Magnum rod bearing question? [Re: racealittle] #180612
01/01/09 06:04 PM
01/01/09 06:04 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
They don't always say "std", I would push the rod up in the cylinder and mic it with something to verify std which it most likely is with that date.
