Re: Engine rebuild. Is this normal?
[Re: 68340GTS]
#180437
01/01/09 03:21 PM
01/01/09 03:21 PM
Posts: 5,080 organ
maximum entropy
organ
how is it without the seal?
[Re: maximum entropy]
#180438
01/01/09 03:24 PM
01/01/09 03:24 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Will it turn by hand if you grab the coutner weights?
Pull a main cap and look for wear on the bearings.
[Re: cdp]
#180440
01/01/09 03:43 PM
01/01/09 03:43 PM
id say its tight. ive only done a few engines but they all turned nicely with just the crank in (lubed of course).
if you didnt check the clearances, you better
[Re: Barnabas_Kriss]
#180446
01/01/09 08:36 PM
01/01/09 08:36 PM
RapidRobert
I'd R&R the crank/bearings clean the saddles & align the thrust bearing halves & oil the journals. If there's still a problem I'd have your machine shop mike everything otherwise there will be an early failure down the line.
