Engine rebuild. Is this normal? #180434
01/01/09 02:18 PM
01/01/09 02:18 PM
Blairsville Pa.
68340GTS Offline OP
68340GTS  Offline OP
Blairsville Pa.
We are rebuilding my nephews 340 and I’m not sure about the crankshaft drag. The book says it should turn by hand with the neoprene rear main seal. After all the caps were torqued to specs the crank will turn by hand but only after it is started by rotating it with a ratchet on the damper bolt. If it sets for a little while it can not spin it until you start it with the ratchet again. It doesn’t feel like it anything is binding but it is snug. Any help would be appreciated. Thanks………..
Re: Engine rebuild. Is this normal? [Re: 68340GTS] #180435
01/01/09 02:20 PM
01/01/09 02:20 PM
Canada
RobR Offline
RobR  Offline
Canada
Sounds like it's a bit too tight...line hone time
Re: Engine rebuild. Is this normal? [Re: 68340GTS] #180436
01/01/09 02:21 PM
01/01/09 02:21 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
If it spins easily with a ratchet then you should be fine. Depending what you used for assembly lube and how much you used will affect the drag.
Re: Engine rebuild. Is this normal? [Re: 68340GTS] #180437
01/01/09 03:21 PM
01/01/09 03:21 PM
organ
maximum entropy Offline
organ
how is it without the seal?
Re: Engine rebuild. Is this normal? [Re: maximum entropy] #180438
01/01/09 03:24 PM
01/01/09 03:24 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Will it turn by hand if you grab the coutner weights?
Pull a main cap and look for wear on the bearings.
Re: Engine rebuild. Is this normal? [Re: NTOLERANCE] #180439
01/01/09 03:40 PM
01/01/09 03:40 PM
MO
cdp Offline
cdp  Offline
MO
did you use plastigage to check clearances? You can pick it up at any parts store, cheap. Check end play at the snout too.
Re: Engine rebuild. Is this normal? [Re: cdp] #180440
01/01/09 03:43 PM
01/01/09 03:43 PM
id say its tight. ive only done a few engines but they all turned nicely with just the crank in (lubed of course).
if you didnt check the clearances, you better
Re: Engine rebuild. Is this normal? [Re: 68340GTS] #180441
01/01/09 04:02 PM
01/01/09 04:02 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Check end play and bearing clearances. Did you set the thrust bearing correctly?
Sheldon
Re: Engine rebuild. Is this normal? [Re: RUNCHARGER] #180442
01/01/09 05:23 PM
01/01/09 05:23 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
With no pistons or rods in there it should turn very easily even with the rubber seal in the rear main. Is it consistent through the rotation or is it tight only in certain spots? I'd start by checking with plasti gauge. Run out and end play should also be checked.
Re: Engine rebuild. Is this normal? [Re: 69Cuda340S] #180443
01/01/09 05:29 PM
01/01/09 05:29 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
If the end play isn't correct, how do you fix it?
Re: Engine rebuild. Is this normal? [Re: dodgeram440] #180444
01/01/09 07:01 PM
01/01/09 07:01 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
when my 383 was getting done at the machine shop, I stopped by to give them some cash and he showed me where they were on it. Crank, bearings, and rear seal were in. He gave it a spin by hand with the counterweights and it probably spun 1 1/2 turns after he let go! I expect this one to make some good power!
Re: Engine rebuild. Is this normal? [Re: farmington] #180445
01/01/09 07:48 PM
01/01/09 07:48 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
Sounds like it is too tight. Check end play, bearing clearances, check crank for straightness, and check the alignment of the main bearing bores.
Re: Engine rebuild. Is this normal? [Re: Barnabas_Kriss] #180446
01/01/09 08:36 PM
01/01/09 08:36 PM
I'd R&R the crank/bearings clean the saddles & align the thrust bearing halves & oil the journals. If there's still a problem I'd have your machine shop mike everything otherwise there will be an early failure down the line.
Re: Engine rebuild. Is this normal? [Re: dodgeram440] #180447
01/01/09 10:53 PM
01/01/09 10:53 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
If its too loose you'll need another crank. If its too tight the thrust surface of the #3 bearing can be carefully rubbed on sand paper to remove some surface. This book covers the procedure:
http://www.amazon.com/How-Rebuild-Small-Block-Mopar-Engines/dp/0895861283
Re: Engine rebuild. Is this normal? [Re: 69Cuda340S] #180448
01/01/09 11:17 PM
01/01/09 11:17 PM
Sparks,Nv.
P
pete Offline
super street
pete  Offline
super street
P
Sparks,Nv.
if it were me I would ask someone like Dram for answers or post this in the race section.
Pete
