Schumacher poly lock motor mounts taller then stoc #1798299
04/08/15 05:15 AM
04/08/15 05:15 AM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
Trying to get my 440 stroker in place, regular shumaker motor mounts are smaller then stock so I hoped that the poly lock ones were taller to clearance center link, reversing center link only makes things tighter thank you
Re: Schumacher poly lock motor mounts taller then stoc [Re: meepmeep70] #1798551
04/08/15 03:30 PM
04/08/15 03:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
What is the question?
- Stu Harmon
Re: Schumacher poly lock motor mounts taller then stoc [Re: meepmeep70] #1798768
04/08/15 07:36 PM
04/08/15 07:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
are the schumacher poly mounts taller than their rubber mounts ?
Do they make rubber mounts ?
Re: Schumacher poly lock motor mounts taller then stoc [Re: meepmeep70] #1798794
04/08/15 08:09 PM
04/08/15 08:09 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I saw somewhere in my interweb travels today, shims to put between the mount and the frame bracket. Might have been on Mancini or Schumacher's site.
What is the center link hitting, pan or headers?
Are poly mounts "taller"? No idea but if you have headers, the mounts will require some kind of heat shield or they will melt. DAMHIK.
Kevin
Re: Schumacher poly lock motor mounts taller then stoc [Re: JohnRR] #1798811
04/08/15 08:28 PM
04/08/15 08:28 PM
weymouth,mass.
weymouth,mass.
. Sorry was asking if they were taller, hitting center link, I tried every which way with the link, used schmucker shims on shumucker regular mounts, I have only 1/4" clearance from pan, I think I need to massage my pan some 😁
Re: Schumacher poly lock motor mounts taller then stoc [Re: meepmeep70] #1798816
04/08/15 08:30 PM
04/08/15 08:30 PM
weymouth,mass.
weymouth,mass.
Sorry for slow reply, Moparts seems to have changed a little not even sure if I replyed☺️Will move to a computer might be this silly phone
Re: Schumacher poly lock motor mounts taller then stoc [Re: meepmeep70] #1799221
04/09/15 10:36 AM
04/09/15 10:36 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Unlike the stock mounts the poly locks don't settle. Same holds true for the Polygraphites. That gives the impression they are taller. It becomes an issue with the fitment of headers or a stock exhaust system from TTI or Accurate. I have run into figment issues using used rubber mounts. I believe the exhaust vendors use stock rubber mounts when the mocked up their systems.
Abe Lincoln
Re: Schumacher poly lock motor mounts taller then stoc [Re: dart4forte] #1799452
04/09/15 03:25 PM
04/09/15 03:25 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Is it an OEM oil pan? I seem to remember an article in Mopar Action (I think) where they used a repro pan that would not clear the drag link. They had to "massage" the pan for clearance.
Re: Schumacher poly lock motor mounts taller then stoc [Re: Jwilli500] #1800192
04/10/15 12:28 PM
04/10/15 12:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No it's not a stock pan .
Re: Schumacher poly lock motor mounts taller then stoc [Re: meepmeep70] #1800270
04/10/15 01:55 PM
04/10/15 01:55 PM
Wahoo Nebr
vette1986 Offline
vette1986  Offline
Wahoo Nebr
We have a set of these that we were going to use on an A12 car. Has anyone had any issues with them not working on that stock setup with an accurate exhaust system?
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: Schumacher poly lock motor mounts taller then stoc [Re: vette1986] #1800404
04/10/15 04:40 PM
04/10/15 04:40 PM
Ontario,Canada
1967GTX440 Offline
1967GTX440  Offline
Ontario,Canada
I put a set in my 1967 GTX 440 along with a transmissiom mount. It did raise the engine I think about an inch . the transmission mount fell out in 2 pieces and the rubber in the motor mounts was sqiuished almost flat.
Re: Schumacher poly lock motor mounts taller then stoc [Re: meepmeep70] #1800449
04/10/15 06:26 PM
04/10/15 06:26 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
The latest generation flat sandwich style locking mount looks thicker than the type I got about 10 years ago which simply a stock rubber mount with a flat head allen capscrew in place to keep the mounts from pulling apart. Schumacher also offers a truck sandwich mount which is considerably thicker than a car mount.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Schumacher poly lock motor mounts taller then stoc [Re: meepmeep70] #1800679
04/10/15 10:35 PM
04/10/15 10:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
meep got it figured out , his centerlink was put in backwards before he bought the car and when he restored the car he put it back assuming it was correct , it wasn't , he's got 3/4" clearance ... but that is with the shcumacher 3/16" shims because the mounts he used were thinner than factory original ... which is the case with the India and Korea sourced mounts I believe.
He'll be replacing those after the first burnout ...
