Re: Schumacher poly lock motor mounts taller then stoc
[Re: meepmeep70]
#1798768
04/08/15 07:36 PM
04/08/15 07:36 PM
Posts: 75,063 U.S.S.A.
JohnRR
U.S.S.A.
are the schumacher poly mounts taller than their rubber mounts ?
Do they make rubber mounts ?
[Re: JohnRR]
#1798811
04/08/15 08:28 PM
04/08/15 08:28 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
Do they make rubber mounts ? . Sorry was asking if they were taller, hitting center link, I tried every which way with the link, used schmucker shims on shumucker regular mounts, I have only 1/4" clearance from pan, I think I need to massage my pan some đ
[Re: meepmeep70]
#1799221
04/09/15 10:36 AM
04/09/15 10:36 AM
Posts: 16,152 Mesa, Arizona
dart4forte
Mesa, Arizona
Unlike the stock mounts the poly locks don't settle. Same holds true for the Polygraphites. That gives the impression they are taller. It becomes an issue with the fitment of headers or a stock exhaust system from TTI or Accurate. I have run into figment issues using used rubber mounts. I believe the exhaust vendors use stock rubber mounts when the mocked up their systems.
âSo if itâs on the internet it must be trueâ
Abe Lincoln
[Re: Jwilli500]
#1800192
04/10/15 12:28 PM
04/10/15 12:28 PM
JohnRR
U.S.S.A.
Is it an OEM oil pan? I seem to remember an article in Mopar Action (I think) where they used a repro pan that would not clear the drag link. They had to "massage" the pan for clearance. No it's not a stock pan .
[Re: meepmeep70]
#1800270
04/10/15 01:55 PM
04/10/15 01:55 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
We have a set of these that we were going to use on an A12 car. Has anyone had any issues with them not working on that stock setup with an accurate exhaust system?
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
[Re: meepmeep70]
#1800449
04/10/15 06:26 PM
04/10/15 06:26 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
The latest generation flat sandwich style locking mount looks thicker than the type I got about 10 years ago which simply a stock rubber mount with a flat head allen capscrew in place to keep the mounts from pulling apart. Schumacher also offers a truck sandwich mount which is considerably thicker than a car mount.
Free advice and worth every penny... Factory trained Slinky rewinder.........
