Identifying B and E-body Dana's #1792615
03/31/15 03:49 PM
03/31/15 03:49 PM
lancaster,california
johnnycuda Offline OP
A friend of a friend supposedly has one of each and may want to sell them as he is a GM guy, I know the B-body is wider and the fact the car housings have provisions for a pinion snubber, I was curious on the casting or stamped numbers on the axles of them both, maybe I can make a deal for both and save them, assuming hes not full of crap and they are actually truck rears....thanks!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Identifying B and E-body Dana's [Re: johnnycuda] #1792616
03/31/15 04:10 PM
03/31/15 04:10 PM
Sec.414,seat 12,White Sox Park
swapman Offline
swapman  Offline
Mopar Rear Axle Dimensions
All measurements are from drum to drum:
1966-1972 A-body 57-1/8″
1962-1963 B-body 58-1/2″
1964-1967 B-body 59-1/2″
1970-1971 Imperial 59-3/4″
1968-1970 B-body 60-1/8″
1970-1974 E-body 61-5/8″
1965-1969 C-body and 1965-1970 A100 Vans 61-3/4″
1965-1966 Imperial 62″
1967-1969 Imperial 62-5/16″
1970-1971 C-body and 1971-1974 B-body 63″
1965-1971 D100 pickup 64″
1969 C-body wagony and 1971-1973 B-body wagon 64-3/8″
1970-1973 C-body and 1972-1974 D100 pickup 64-3/8″
Rear end widths, drum-to-drum:
A BODY ’66-’72: 57-1/8″
B BODY ’62-’63: 58-1/2″ (And ’64 Max Wedge)
’64: 60-7/8″ (Exc.Max Wedge)
’65-’67: 59-1/2″
’68-’70: 60-1/8″
’71-’74: 63″
’71-’73 wagon: 64-3/8″
C BODY ’65-’69: 61.75″
’70-’71: 63.0″ (Chrysler & Fury)
’70-’73: 64-3/8″ (and ’69 wagon)
IMPERIAL ’65-’66: 61-15/16″
’67-’69: 62-5/16″
’70-’71: 59-3/4″
’72-’73: 64-9/16″
E BODY ’70-’74: 61-5/8″
A100 ’65-’70: 61-3/4″
D100 ’65-’71: 63-15/16″
’72-’74: 64-3/8″
Re: Identifying B and E-body Dana's [Re: swapman] #1792617
03/31/15 07:18 PM
03/31/15 07:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
’65-’67: 59-1/2″
’68-’70: 60-1/8″
’71-’74: 63″
’67-’69: 62-5/16″
’70-’71: 59-3/4″
’72-’73: 64-9/16″
’72-’74: 64-3/8″
The board software does not like your copy n paste ...
There will be a stamped BOM number on the right side tube
Re: Identifying B and E-body Dana's [Re: JohnRR] #1792618
03/31/15 07:30 PM
03/31/15 07:30 PM
The BOM number was what I was wondering about, do you know what number they should have on it for a E or B Dana, how do you tell the year?, thanks guys!
Re: Identifying B and E-body Dana's [Re: johnnycuda] #1792619
03/31/15 07:46 PM
03/31/15 07:46 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Simple,the shorter of the two is b-body,68 and earlier had drain plug on bottom,eliminated in 69 and later.
Re: Identifying B and E-body Dana's [Re: 62maxwgn] #1792620
03/31/15 09:16 PM
03/31/15 09:16 PM
I knew the width difference being roughly 3", the BOM numbers or casting numbers was the part I was curious about.
Re: Identifying B and E-body Dana's [Re: johnnycuda] #1792621
03/31/15 10:33 PM
03/31/15 10:33 PM
Indiana
68_661charger Offline
Indiana
When you say drum to drum is it the backside of the drum edge that overlaps the backing plate or the drum face?
Re: Identifying B and E-body Dana's [Re: johnnycuda] #1792622
03/31/15 10:34 PM
03/31/15 10:34 PM
Washington/Las Vegas
1971 Gran Coupe Offline
Re: Identifying B and E-body Dana's [Re: 62maxwgn] #1792623
03/31/15 11:39 PM
03/31/15 11:39 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Unless it is a 71/2 B which is wider than an E.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Identifying B and E-body Dana's [Re: johnnycuda] #1792624
04/01/15 02:49 PM
04/01/15 02:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
BOM
Re: Identifying B and E-body Dana's [Re: John_Kunkel] #1792625
04/01/15 03:06 PM
04/01/15 03:06 PM
BOM
Wow, thanks, John...just what I was looking for. Its amazing the information the guys here have amassed over the years, spec sheets, build numbers etc..not to mention sheer experience.
