Has the QC on 440 Source cranks improved? #1788936
03/26/15 06:41 PM
03/26/15 06:41 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
I'm thinking about building a stroker and would like to know if the 440 Source cranks are better these days for grinding precision (taper and runout) than they used to be. It would be a low deck stroker with a 3.91" stroke and not many places even offer a crank like this that I know of.
Re: Has the QC on 440 Source cranks improved? [Re: PorkyPig] #1788937
03/26/15 07:02 PM
03/26/15 07:02 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I have low deck Molnar 3.91 cranks in stock. If you are East coast,shipping may be a little less. If your West coast, then maybe 440 Source would be closer. Let me know if I can help,otherwise I am sure Brandon can help you out.
RIP Monte Smith
Re: Has the QC on 440 Source cranks improved? [Re: PorkyPig] #1788938
03/26/15 07:08 PM
03/26/15 07:08 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
I built a 526 stroker and the crank was fine, runs great.
Re: Has the QC on 440 Source cranks improved? [Re: PorkyPig] #1788939
03/26/15 07:11 PM
03/26/15 07:11 PM
AndyF Offline
AndyF  Offline
I've used several 440Source cranks over the years and have never had an issue with them. If money is no object then I use Callies, but most people have a budget that doesn't allow all premium parts.
Re: Has the QC on 440 Source cranks improved? [Re: PorkyPig] #1788940
03/26/15 07:22 PM
03/26/15 07:22 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I just received a 4.25" as part of a stroker kit, according to my machine shop the grinding aspect of it was great. They just took a tiny bit too much on the balance.
Re: Has the QC on 440 Source cranks improved? [Re: CompWedgeEngines] #1788941
03/26/15 07:41 PM
03/26/15 07:41 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Can you tell me if the 2.20 rod journal of the Molnar crank is cut for a Chevy width rod or a Chrysler width rod?
Re: Has the QC on 440 Source cranks improved? [Re: PorkyPig] #1788942
03/26/15 09:45 PM
03/26/15 09:45 PM
Canada
Criterion Offline
Criterion  Offline
Canada
The one I have here is 2.010 wide ~ Chevy.
Re: Has the QC on 440 Source cranks improved? [Re: AndyF] #1788943
03/26/15 11:36 PM
03/26/15 11:36 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Same for me, my 4.25 crank was awesome, checked by my engine builder. Came out real close grinded a tad nothing serious
Mikey
1969 Dodge Dart Swinger
Re: Has the QC on 440 Source cranks improved? [Re: MikeyT] #1788944
03/27/15 12:16 AM
03/27/15 12:16 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
No problem with mine - which I bought about 5 years ago.
The tales of bad cranks seem to have been rumors perpetrated by people who had no actual first hand knowledge but are just down on products made in China.
Re: Has the QC on 440 Source cranks improved? [Re: Stanton] #1788945
03/27/15 12:36 AM
03/27/15 12:36 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Mine wasn't a 440 Source but was Chinese. Improperly ground so kept eating bearings and snout was over 0.001 inches too small........
Re: Has the QC on 440 Source cranks improved? [Re: markz528] #1788946
03/27/15 12:53 AM
03/27/15 12:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mine been going strong for over 3 years. Ron
Re: Has the QC on 440 Source cranks improved? [Re: Stanton] #1788947
03/27/15 02:00 AM
03/27/15 02:00 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Re: Has the QC on 440 Source cranks improved? [Re: 383man] #1788948
03/27/15 02:09 AM
03/27/15 02:09 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I never heard of 440 Source being out of tolerance. Mine was checked and found to be right on. Still running strong after about 300 1/4 mile passes. Back when I bought my rotating assembly , Brandon was taking all kinds of flack from the peanut gallery for selling off shore stuff. As stated above, I couldn't afford Callies
Re: Has the QC on 440 Source cranks improved? [Re: markz528] #1788949
03/27/15 04:39 AM
03/27/15 04:39 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
But...parts quality ultimately falls to the installer. You NEVER run ANY aftermarket internal part without a thorough check, right??
Re: Has the QC on 440 Source cranks improved? [Re: cudadoug] #1788950
03/27/15 09:27 AM
03/27/15 09:27 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'll go a step further. You never run any stock or aftermarket internal or external part without a thorough check. RIGHT???
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Has the QC on 440 Source cranks improved? [Re: pittsburghracer] #1788951
03/27/15 09:33 AM
03/27/15 09:33 AM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Has the QC on 440 Source cranks improved? [Re: Stanton] #1788952
03/27/15 10:12 AM
03/27/15 10:12 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Bull$hit. More than one person who builds / built engines for a living has provided details in the past on certain cranks whose finish tolerances were far from ideal (excessive journal taper, inconsistent sizing from one journal to the next).
I know some of the brands seem to have gotten better. My 2nd Eagle crank is surprisingly good (my first one needed the mains cut .010"). The only thing I don't like was that the crank snout where the damper fits was on the small side, so I needed to buy a new SFI damper to make sure the press fit was acceptable. My original SFI damper had already been honed to fit an OEM-sized snout and would have been too loose.
Just because some people don't want to hear that their budget parts might not have been machined as precisely as more expensive & higher quality items doesn't make it a "rumor".
Re: Has the QC on 440 Source cranks improved? [Re: BradH] #1788953
03/27/15 01:18 PM
03/27/15 01:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
there has been many documented cases. Dan we need you and many of them were 440source
Re: Has the QC on 440 Source cranks improved? [Re: BradH] #1788954
03/27/15 02:54 PM
03/27/15 02:54 PM
rowin4 Offline
rowin4  Offline
Here we go, The question was about 440 Source and now your saying how your Eagle crank was a piece of crap. Just to let you know I had my Eagle crank checked by a top Engine builder and it was good to go. If my 440 Source crank needed to be turned .010 it would have been sent back.
Re: Has the QC on 440 Source cranks improved? [Re: rowin4] #1788955
03/27/15 06:55 PM
03/27/15 06:55 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i got one last year. i was told by the engine builder it was good but on the large side of spec. so he got .001 bearings i think. other than he said it was freeking hard to drill for balance he said good to go.
