Spark Plug replacment on 5.7L Hemi Ram #1783793
03/19/15 04:56 PM
03/19/15 04:56 PM
Morningside
AdventurerSport Offline OP
waaaay out there in left field
Morningside
When have you guys been changing plugs on 5.7L Rams? I think that I saw somewhere that they said 70,000 mile recommended service is plug change...?
My 2011 has 73,000 miles (give or take) and runs just fine, plenty of power, good mileage, no issues at all. When should I consider changing plugs?
Then, when I'm due, how hard is this? Simple as any, or tricks/special tools needed?
What spark plugs are you replacing the factory ones with? Looking for suggestions on this issue.
Thank you!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: AdventurerSport] #1783794
03/19/15 05:30 PM
03/19/15 05:30 PM
P
Paul_Fancsali Offline
P
Probably should change them before they weld themselves into the heads, and yet I can't help but wonder if its better to leave well enough alone
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: AdventurerSport] #1783795
03/19/15 05:52 PM
03/19/15 05:52 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
When I had my 2012 I was researching this, and you are recommended to change spark plugs at 36k miles. The 2013 and up Ram's come from the factory with platinum plugs that are supposed to last until 100k.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: KingTuna] #1783796
03/19/15 06:05 PM
03/19/15 06:05 PM
Morningside
Morningside
OK, thank you! Platinum plugs go 100K on '13-up but what did '12-down have? Copper? Old style Champions?
JS
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: AdventurerSport] #1783797
03/19/15 07:08 PM
03/19/15 07:08 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
You should change yours every 32,000 miles per Chrysler. 2014 and up is every 100,000 miles per Chrysler.
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: teflon] #1783798
03/19/15 07:11 PM
03/19/15 07:11 PM
Morningside
Morningside
OK, thank you!
Any advice on replacement plugs? Would upgrading to platinum allow me to go 100,000 til the next set?
Thanks!
JS
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: AdventurerSport] #1783799
03/19/15 07:31 PM
03/19/15 07:31 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
Thank you!
JS
What's the trick to changing #7 plug? Access prettymuch blocked by master cylinder?
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: RTDaddy] #1783800
03/19/15 07:51 PM
03/19/15 07:51 PM
Minn
SportF Offline
SportF  Offline
Minn
On the back plugs, you have to drop in the plug socket, then the "right size" extension, then put on the ratchet. Once its loose, ratchet off, extension out, magnet on the socket, and/or plug.
I have changed the plugs on my '03 at 30K, then 70K. Both times I thought the plugs looked great and it was kind of a waste.
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: AdventurerSport] #1783801
03/19/15 08:29 PM
03/19/15 08:29 PM
Lakewood, Colorado
runnerrt Offline
runnerrt  Offline
Lakewood, Colorado
My 04 had regular resistor Champions in it. I do them ever 36k. Pretty easy to do other than the 2 new the brake master
1969 Super Bee High School car I got back 2004 Ram 2500
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: runnerrt] #1783802
03/19/15 09:32 PM
03/19/15 09:32 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Snap-on makes a socket that is thin enough to go into the opening also best get a locking extension too so you don't loose the socket in there.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: Savoy1964] #1783803
03/22/15 05:22 PM
03/22/15 05:22 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Short extensions like pulling pipe out of a well. anti seize on new plugs and a magnet to get plug socket if it drops down.
36000 miles or 50,000 km they say not to use platinum if it don't call for them something to do with computer so I'm told at least. I put same champs back in runs perfect guess I'm do to do it again any day now. :-(
Re: Spark Plug replacment on 5.7L Hemi Ram [Re: Dodgem] #1783804
03/22/15 05:59 PM
03/22/15 05:59 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I can't believe anyone would choose to leave spark plugs in for 100,000 miles. They get pretty cozy in there and are a pisser to break loose at that point.
