Spark Plug replacment on 5.7L Hemi Ram
#1783793
03/19/15 04:56 PM
03/19/15 04:56 PM
Posts: 6,019 Morningside
AdventurerSport
waaaay out there in left field
Morningside
When have you guys been changing plugs on 5.7L Rams? I think that I saw somewhere that they said 70,000 mile recommended service is plug change...?
My 2011 has 73,000 miles (give or take) and runs just fine, plenty of power, good mileage, no issues at all. When should I consider changing plugs?
Then, when I'm due, how hard is this? Simple as any, or tricks/special tools needed?
What spark plugs are you replacing the factory ones with? Looking for suggestions on this issue.
Thank you!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: Spark Plug replacment on 5.7L Hemi Ram
[Re: AdventurerSport]
#1783795
03/19/15 05:52 PM
03/19/15 05:52 PM
Posts: 416 Georgia
KingTuna
Georgia
When I had my 2012 I was researching this, and you are recommended to change spark plugs at 36k miles. The 2013 and up Ram's come from the factory with platinum plugs that are supposed to last until 100k.
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
[Re: KingTuna]
#1783796
03/19/15 06:05 PM
03/19/15 06:05 PM
AdventurerSport
Morningside
OK, thank you! Platinum plugs go 100K on '13-up but what did '12-down have? Copper? Old style Champions? JS
[Re: teflon]
#1783798
03/19/15 07:11 PM
03/19/15 07:11 PM
AdventurerSport
Morningside
You should change yours every 32,000 miles per Chrysler. 2014 and up is every 100,000 miles per Chrysler.
OK, thank you!
Any advice on replacement plugs? Would upgrading to platinum allow me to go 100,000 til the next set?
Thanks!
JS
#1783799
03/19/15 07:31 PM
03/19/15 07:31 PM
Posts: 942 Virginia, US
RTDaddy
super street
super street
Virginia, US
Thank you!
JS
What's the trick to changing #7 plug? Access prettymuch blocked by master cylinder?
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
[Re: RTDaddy]
#1783800
03/19/15 07:51 PM
03/19/15 07:51 PM
Posts: 1,213 Minn
SportF
Minn
On the back plugs, you have to drop in the plug socket, then the "right size" extension, then put on the ratchet. Once its loose, ratchet off, extension out, magnet on the socket, and/or plug.
I have changed the plugs on my '03 at 30K, then 70K. Both times I thought the plugs looked great and it was kind of a waste.
#1783801
03/19/15 08:29 PM
03/19/15 08:29 PM
Posts: 550 Lakewood, Colorado
runnerrt
Lakewood, Colorado
My 04 had regular resistor Champions in it. I do them ever 36k. Pretty easy to do other than the 2 new the brake master
1969 Super Bee High School car I got back
2004 Ram 2500
[Re: runnerrt]
#1783802
03/19/15 09:32 PM
03/19/15 09:32 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Snap-on makes a socket that is thin enough to go into the opening also best get a locking extension too so you don't loose the socket in there.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
