Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location?
[Re: D_C]
#1782535
03/18/15 05:48 AM
03/18/15 05:48 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
See attached. It is the switch right next to the steering column.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: D_C]
#1782537
03/18/15 07:35 AM
03/18/15 07:35 AM
GTSDart340
Laveen, Arizona
Sorry for the bad pics. This is a 75 W100, so I'd assume its the same. This is the best pic I have of the light.
[Re: D_C]
#1782541
03/19/15 05:08 AM
03/19/15 05:08 AM
GTSDart340
Laveen, Arizona
There is an oval shaped hole, as thre is an indicator light next to the switch. If you have the bezel you will see how it attatches.
