'72 - '80 Dodge Pickup Cargo Lamp Switch Location? #1782534
03/18/15 05:39 AM
03/18/15 05:39 AM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
I just bought a Factory Cargo Lamp Switch with bezel and wiring harness. It is of the '72 - '80 Style as is the truck it is going into.
My '74 was originally a Utility Bed Truck, so it did not come with the Cargo Light Option. The Utility Bed is long gone, replaced by an 8-foot Sweptline Bed.
Where on the Dash is the Factory On/Off-Indicator-Light Switch/Bezel, supposed to be mounted?
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: D_C] #1782535
03/18/15 05:48 AM
03/18/15 05:48 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
See attached. It is the switch right next to the steering column.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: GTSDart340] #1782536
03/18/15 06:24 AM
03/18/15 06:24 AM
D_C Offline OP
D_C  Offline OP
Thanks for the quick reply and picture.
Wonder if that would be the same location for my '74?
Also, do you happen to have a picture of the Light itself? I have the Switch, Bezel and Wiring, but I still need to get a Cargo Lamp housing, or until then, mount a generic one to.the cab.
Thanks Again.
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: D_C] #1782537
03/18/15 07:35 AM
03/18/15 07:35 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Sorry for the bad pics. This is a 75 W100, so I'd assume its the same. This is the best pic I have of the light.
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: GTSDart340] #1782538
03/18/15 03:27 PM
03/18/15 03:27 PM
D_C Offline OP
D_C  Offline OP
Thanks. The picture is good enough. Was just wondering what it should look like.
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: D_C] #1782539
03/18/15 11:52 PM
03/18/15 11:52 PM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
72-80 all the same, perhaps this is a better pic of the dash.
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: Ramtough] #1782540
03/19/15 04:56 AM
03/19/15 04:56 AM
D_C Offline OP
D_C  Offline OP
Thanks for the reply and pic. Was wondering, does the plastic bezel mount to the flat surface of the metal dash, or is there an oval-shaped hole cut into the metal dash?
Since my truck did not come with this factory option, currently there is only a nickel-sized hole near the steering column. Would I need to cut out a larger hole in the sheet metal to mount this correctly?
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: D_C] #1782541
03/19/15 05:08 AM
03/19/15 05:08 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
There is an oval shaped hole, as thre is an indicator light next to the switch. If you have the bezel you will see how it attatches.
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: Ramtough] #1782542
03/19/15 10:05 AM
03/19/15 10:05 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
I don't know about that. This was in a 76.
OIF V and OEF X veteran and proud of it!
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: 69HemiGTX] #1782543
03/19/15 10:05 AM
03/19/15 10:05 AM
69HemiGTX Offline
69HemiGTX  Offline
This was in an 80.
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: 69HemiGTX] #1782544
03/19/15 03:32 PM
03/19/15 03:32 PM
D_C Offline OP
D_C  Offline OP
Thanks for the replies.
The first picture (1976) is what the switch and bezel I bought look like (knob with light to the left in bezel), but I don't have a precut hole in the metal dash of the size and shape to fit the bezel into and mount it flush.
So, it looks like I will need to cut an oval hole in the dash.
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: D_C] #1782545
03/20/15 11:19 AM
03/20/15 11:19 AM
69HemiGTX Offline
69HemiGTX  Offline
I found a pic that shows the hole. It's pretty big so you can see some detail.
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: 69HemiGTX] #1782546
03/20/15 11:23 AM
03/20/15 11:23 AM
69HemiGTX Offline
69HemiGTX  Offline
This pic shows the difference in roof lines, but it's the best pic of a cargo light I have.
Re: '72 - '80 Dodge Pickup Cargo Lamp Switch Location? [Re: 69HemiGTX] #1782547
03/20/15 08:55 PM
03/20/15 08:55 PM
D_C Offline OP
D_C  Offline OP
Thanks for the pics. Definitely is a good sized hole.
