727 Trans- gas vs diesel #1777435
03/11/15 10:11 PM
03/11/15 10:11 PM
smyrna,tn
draginmopars Offline OP
smyrna,tn
have a 727 diesel- short shaft/ fixed yoke.
727 gas- long shaft, slip yoke
Want to make the diesel- long shaft /slip yoke
Can I swap the shaft and tail housing out of the gas , into the diesel
thanks
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: 727 Trans- gas vs diesel [Re: draginmopars] #1777436
03/12/15 03:13 PM
03/12/15 03:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on the year; if both the gas and the diesel are '93 or earlier or both are '94 it's a straight-across swap but if one is '94 and the other is '93-earlier you'll have to swap the front planetary also.
Also, but be aware that the gas and the diesel use different governors so, when swapping output shafts, swap the diesel governor assembly onto the gas output shaft.
