Depends on the year; if both the gas and the diesel are '93 or earlier or both are '94 it's a straight-across swap but if one is '94 and the other is '93-earlier you'll have to swap the front planetary also.
Also, but be aware that the gas and the diesel use different governors so, when swapping output shafts, swap the diesel governor assembly onto the gas output shaft.
The INTERNET, the MISinformation superhighway
