Headlight upgrade questions #1772102
03/05/15 01:03 PM
03/05/15 01:03 PM
Port Huron, Michigan
MI_Custumz Offline OP
Can these headlights be installed as a plug and play? Saw them and might be interested. Either the custom or LED ones on this page. http://www.lmctruck.com/icatalog/dc/full.aspx?Page=33
Re: Headlight upgrade questions [Re: MI_Custumz] #1772103
03/05/15 02:44 PM
03/05/15 02:44 PM
The link is for a truck restoration site, but many cars use the 7" headlight.
Re: Headlight upgrade questions [Re: MI_Custumz] #1772104
03/05/15 03:39 PM
03/05/15 03:39 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
The LED version is a 7" round, Trucklite, 27270, excellent replacement, and low power demand. About $165 on Ebay. Retail varies ...
Not sure why they did it, but if you have Waste Management trash trucks in your area, look at the lights ... at least in my area it seems they have replaced ALL the incandescent headlights with LEDs.
It takes gasoline to interest me.
Re: Headlight upgrade questions [Re: VL21] #1772105
03/05/15 05:09 PM
03/05/15 05:09 PM
scratchnfotraction Offline
I will have to dig up the notes again, kinda spendy too.
but the LED lights I looked at was rectangle and for the D series trucks and would fix any low idle low output dim lights on a mopar by only drawing as much voltage as a normal 1157 brake/turn bulb both elements burning.
IIRC they were for a new 2013 freightliner @ 365$ a set. IIRC the had the 7" round in that same line of LED bulbs also.
that would be worth the $ on any older mopar as no wiring/relay/charging system upgrades needed.
Re: Headlight upgrade questions [Re: VL21] #1772106
03/05/15 05:10 PM
03/05/15 05:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run Halogens in all the cars.Just replace the standards.The halogens pull less amps.They will light up the road.Rocky
Chrysler Firepower
Re: Headlight upgrade questions [Re: therocks] #1772107
03/07/15 12:44 PM
03/07/15 12:44 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I'd be interested in hearing actual user experience with LED headlights or foglights. My casual observations with LED's so far is that they are great for making sure you are seen. Very intense for brake lights or daytime running lights where you are looking directly at the LED. But when you are standing behind the LED looking forward, the light output on the ground is poor for lighting a large area. This tech is changing quickly, maybe they are better now. Is any manufacturer using LED headlights from the factory now?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Headlight upgrade questions [Re: GO_Fish] #1772108
03/07/15 02:15 PM
03/07/15 02:15 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I won't swear to it, and I don't know any one with one, and I don't go there only of necessity,
BUT
it sure looks like the new model Harleys all have LED lighting ...
Maybe they are HID, not sure.
Re: Headlight upgrade questions [Re: VL21] #1772109
03/07/15 02:40 PM
03/07/15 02:40 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I know some of the CVO models do have the LED headlights...was just looking at them a couple days ago while picking up a bike.
Some cars too... Audi comes to mind. (And others I would imagine..)
Re: Headlight upgrade questions [Re: OzHemi] #1772110
03/07/15 07:51 PM
03/07/15 07:51 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
How are LED bulbs like THESE ?
Been thinking about them for my Dakota (after I install new lenses).
John
Re: Headlight upgrade questions [Re: GO_Fish] #1772111
03/07/15 08:16 PM
03/07/15 08:16 PM
places
79powerwagon Offline
places
Not always the case! We use a lot of Optronics lights at work, and some of their tiny auxiliary lights are truly remarkable! They have a little cube LED light with ONE diode in it that makes a better headlight than the ones on my truck! As we move forward, all of our lights used on our DOT and TC vehicles will be LED.
http://www.optronicsinc.com/PRODUCTS/LEDLighting/LEDWorkAG/Products.aspx?SeriesID=658
A lot of the stuff on ebay and the like are pure rubbish.
Re: Headlight upgrade questions [Re: 79powerwagon] #1772112
03/07/15 09:00 PM
03/07/15 09:00 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I agree, LED's are advancing quickly, but like you say, so much out there is junk. I'd like to see a side by side comparison of quality LED low beams at 50 yards next to HID low beams at 50 yards.
Re: Headlight upgrade questions [Re: GO_Fish] #1772113
03/10/15 05:05 AM
03/10/15 05:05 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
Some Acuras and Cadillacs use LEDs for headlights in stock form now, there may be others.
Like all things, quality is all over the board with LED lights.
For specifics on the Trucklite/JW Speaker/etc. 7" LED headlights I'd spend some time on the Wrangler and Harley forums.
Last I read the LED headlights put out about 2,000 lumens. Halogens run about 1,100 and quality HIDs are about 3,300.
Although this doesn't exactly apply to 7" rounds, the info may be helpful. I've spent a lot of time and money trying to get the best possible lighting on my '99 Grand Cherokee.
1)New aftermarket assemblies with halogen bulbs($100)...poor light output but very good beam cutoff and acceptable pattern.
2)Replaced halogen bulbs with Sylvania Silverstar Ultras($50)...good output and cutoff, poor pattern.
3) Replaced Silverstars with LED bulbs in a 9006 configuration GTR Lighting($180)...great output, fuzzy cutoff, scattered pattern.
4) Gutted low-beam side of housing for projector retrofit ( not Ebay projector replacements) with 35 watt 5k HIDs The Retrofit Source ($270)... Amazing output, razor sharp cutoff, ridiculous amount of light that is evenly distributed from directly in front of the vehicle all the way out to the cutoff and wider than any other light tested. The kit was expensive. It took me 2 days and lots of cursing to install but the results are better than I could have imagined. I just wish I'd done it first and saved all the other money to upgrade another rig.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: Headlight upgrade questions [Re: MI_Custumz] #1772114
03/17/15 10:10 AM
03/17/15 10:10 AM
Guitar Jones Offline
I bought the halogen rectangulars for my 92 D250 along with the relay kit. Super simple to install and although I did have to readjust them I'm very happy with them. It was a huge upgrade from the sealed beams. I did have to modify (cut) the back of the headlight bucket as the hole in the back was only a semi circle and you need a full circle opening for the lamps to fit. Other than that it was two ground wires, two battery hookups and mounting two relays. Everything else was just plug and play.
Re: Headlight upgrade questions [Re: Cheeto] #1772115
03/17/15 12:10 PM
03/17/15 12:10 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I'm looking into doing this myself....the only thing I havn't figured out, is how to properly set the projector housings inside the housing so that it'll only take minor adjustments to properly aim them once in the vehicle...
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Headlight upgrade questions [Re: shanker] #1772116
03/17/15 04:20 PM
03/17/15 04:20 PM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
While you have the housings apart (clear lens removed) you install the projector assembly, install the whole housing back in the car and rotate the projector until it is level. Remove the housings, seal the clear outer lens back on and then re-install the complete housing and adjust as normal for height. Time consuming but worth the effort.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: Headlight upgrade questions [Re: Cheeto] #1772117
03/29/15 01:36 AM
03/29/15 01:36 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Once you have the projector level, how are you fixing it in place in the old halogen light housing? And making it air tight? Lots of silicone?
Re: Headlight upgrade questions [Re: GO_Fish] #1772118
03/30/15 09:59 PM
03/30/15 09:59 PM
IN
ahy Offline
ahy  Offline
IN
I used the 7" round LMC Halogen lights on a brand F PU. Also the relay kit. Big improvement. As mentioned above I did have to cut a bigger hole in the back of the headlight bucket.
I fed the relays through a 30 amp breaker (parts store) and 10 gauge wire. I had to lengthen some of the individual headlight leads with 12 gauge wire to get wire routing I liked.
Re: Headlight upgrade questions [Re: GO_Fish] #1772119
03/31/15 04:38 AM
03/31/15 04:38 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
The projector has a hollow threaded shaft that feeds through the bulb hole from front to back (opposite of how you install a regular bulb). A large nut secures it from the "engine side" of the housing. There is a silicone washer that slides on the threaded shaft before passing it through the housing. This seals the bulb opening and helps to keep the projector from rotating.
As for air tight, most factory housings these days are vented to prevent condensation. I did use silicone to seal the clear lens back on though.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
