Re: Headlight upgrade questions
[Re: MI_Custumz]
#1772104
03/05/15 03:39 PM
03/05/15 03:39 PM
Posts: 1,357 central Florida
VL21
central Florida
The LED version is a 7" round, Trucklite, 27270, excellent replacement, and low power demand. About $165 on Ebay. Retail varies ... Not sure why they did it, but if you have Waste Management trash trucks in your area, look at the lights ... at least in my area it seems they have replaced ALL the incandescent headlights with LEDs.
It takes gasoline to interest me.
[Re: VL21]
#1772106
03/05/15 05:10 PM
03/05/15 05:10 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I run Halogens in all the cars.Just replace the standards.The halogens pull less amps.They will light up the road.Rocky
Chrysler Firepower
[Re: therocks]
#1772107
03/07/15 12:44 PM
03/07/15 12:44 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I'd be interested in hearing actual user experience with LED headlights or foglights. My casual observations with LED's so far is that they are great for making sure you are seen. Very intense for brake lights or daytime running lights where you are looking directly at the LED. But when you are standing behind the LED looking forward, the light output on the ground is poor for lighting a large area. This tech is changing quickly, maybe they are better now. Is any manufacturer using LED headlights from the factory now?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: VL21]
#1772109
03/07/15 02:40 PM
03/07/15 02:40 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
it sure looks like the new model Harleys all have LED lighting ...
Maybe they are HID, not sure.
I know some of the CVO models do have the LED headlights...was just looking at them a couple days ago while picking up a bike.
Some cars too... Audi comes to mind. (And others I would imagine..)
[Re: OzHemi]
#1772110
03/07/15 07:51 PM
03/07/15 07:51 PM
Posts: 16,819 Between Houston & Galveston TX
SattyNoCar
How are LED bulbs like THESE ? Been thinking about them for my Dakota (after I install new lenses).
John
[Re: GO_Fish]
#1772111
03/07/15 08:16 PM
03/07/15 08:16 PM
Posts: 27,728 places
79powerwagon
places
Not always the case! We use a lot of Optronics lights at work, and some of their tiny auxiliary lights are truly remarkable! They have a little cube LED light with ONE diode in it that makes a better headlight than the ones on my truck! As we move forward, all of our lights used on our DOT and TC vehicles will be LED.
http://www.optronicsinc.com/PRODUCTS/LEDLighting/LEDWorkAG/Products.aspx?SeriesID=658
A lot of the stuff on ebay and the like are pure rubbish.
[Re: 79powerwagon]
#1772112
03/07/15 09:00 PM
03/07/15 09:00 PM
GO_Fish
Maryland
I agree, LED's are advancing quickly, but like you say, so much out there is junk. I'd like to see a side by side comparison of quality LED low beams at 50 yards next to HID low beams at 50 yards.
Scott B.
[Re: GO_Fish]
#1772113
03/10/15 05:05 AM
03/10/15 05:05 AM
Posts: 1,965 ID/MT
Cheeto
ID/MT
Some Acuras and Cadillacs use LEDs for headlights in stock form now, there may be others. Like all things, quality is all over the board with LED lights. For specifics on the Trucklite/JW Speaker/etc. 7" LED headlights I'd spend some time on the Wrangler and Harley forums. Last I read the LED headlights put out about 2,000 lumens. Halogens run about 1,100 and quality HIDs are about 3,300. Although this doesn't exactly apply to 7" rounds, the info may be helpful. I've spent a lot of time and money trying to get the best possible lighting on my '99 Grand Cherokee. 1)New aftermarket assemblies with halogen bulbs($100)...poor light output but very good beam cutoff and acceptable pattern. 2)Replaced halogen bulbs with Sylvania Silverstar Ultras($50)...good output and cutoff, poor pattern. 3) Replaced Silverstars with LED bulbs in a 9006 configuration GTR Lighting($180)...great output, fuzzy cutoff, scattered pattern. 4) Gutted low-beam side of housing for projector retrofit ( not Ebay projector replacements) with 35 watt 5k HIDs The Retrofit Source ($270)... Amazing output, razor sharp cutoff, ridiculous amount of light that is evenly distributed from directly in front of the vehicle all the way out to the cutoff and wider than any other light tested. The kit was expensive. It took me 2 days and lots of cursing to install but the results are better than I could have imagined. I just wish I'd done it first and saved all the other money to upgrade another rig.
Cheeto It's not perfect. It's not correct. It's not yours!
[Re: MI_Custumz]
#1772114
03/17/15 10:10 AM
03/17/15 10:10 AM
Guitar Jones
Can these headlights be installed as a plug and play? Saw them and might be interested. Either the custom or LED ones on this page. http://www.lmctruck.com/icatalog/dc/full.aspx?Page=33
I bought the halogen rectangulars for my 92 D250 along with the relay kit. Super simple to install and although I did have to readjust them I'm very happy with them. It was a huge upgrade from the sealed beams. I did have to modify (cut) the back of the headlight bucket as the hole in the back was only a semi circle and you need a full circle opening for the lamps to fit. Other than that it was two ground wires, two battery hookups and mounting two relays. Everything else was just plug and play.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: shanker]
#1772116
03/17/15 04:20 PM
03/17/15 04:20 PM
Posts: 1,965 ID/MT
Cheeto
ID/MT
While you have the housings apart (clear lens removed) you install the projector assembly, install the whole housing back in the car and rotate the projector until it is level. Remove the housings, seal the clear outer lens back on and then re-install the complete housing and adjust as normal for height. Time consuming but worth the effort.
[Re: Cheeto]
#1772117
03/29/15 01:36 AM
03/29/15 01:36 AM
GO_Fish
Maryland
Once you have the projector level, how are you fixing it in place in the old halogen light housing? And making it air tight? Lots of silicone?
Scott B.
