600 cubic inch small block Chevy #1771071
03/04/15 01:19 PM
03/04/15 01:19 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
I'm a diehard Mopar guy and I don't ever see that changing but this is one pretty piece.
http://www.enginelabs.com/news/cfe-develops-600-cubic-inch-small-block-engine/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 600 cubic inch small block Chevy [Re: pittsburghracer] #1771072
03/04/15 01:36 PM
03/04/15 01:36 PM
dogdays Offline
dogdays  Offline
Let me be the first to say on this forum that it's not a smallblock.
4.6 bore spacing is greater than a Firepower Hemi, just slightly less than Olds or Pontiac motors. The stock chevy bigblock deck is 9.800. 9.5 is ford 351W territory, so that's more like it, but a 10.2" deck engine with 4.6 bore spacing is really close to a Buick 455.
Yup, the terms smallblock and bigblock etc are not formally defined so anything goes, but I think this is stretching the definition past where I'm comfortable.
I'd also say that any #$23,000 engine SHOULD be impressive.
R.
Re: 600 cubic inch small block Chevy [Re: pittsburghracer] #1771073
03/04/15 02:36 PM
03/04/15 02:36 PM
an8sec70cuda Offline
Back in 2007 or so, there was a grudge car from either NJ or NY that had a motor that they claimed was a small block. It was a big Sonny's motor, but definitely not a typical Sonny's big block. It was in the black "022" Camaro of Deuce Staley w/ Harry O driving...those involved w/ grudge racing will know the car.
No idea how big it was, but it was a monster if it was really considered a small block. He got his butt cut by a local boy down here the night I saw it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 600 cubic inch small block Chevy [Re: pittsburghracer] #1771074
03/04/15 03:31 PM
03/04/15 03:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Yup, it's a small block... except for the block.
SB/BB has no real meaning when both the bore pitch and deck height are invented.
Boffin Emeritus
Re: 600 cubic inch small block Chevy [Re: polyspheric] #1771075
03/04/15 03:51 PM
03/04/15 03:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why is it even an issue? It's not a factory block. Wouldn't be easier just to rate engines/classes by cubic inches? So a guy drives up...I mean pulls his car off the trailer with that thing in it and beats a guy w/ a 512 cubic inch factory BB and he can say I just beat up on a Big Block?
Coming soon!!!!
Re: 600 cubic inch small block Chevy [Re: Mr.Yuck] #1771076
03/04/15 04:11 PM
03/04/15 04:11 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
No, it's a small block. It was stated that "you can even bolt a stock small block water pump to it"...so there you go!
Re: 600 cubic inch small block Chevy [Re: TheOtherDodge] #1771077
03/04/15 04:23 PM
03/04/15 04:23 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Need to do this with the G3 platform.
Big block small doesn't matter.
Re: 600 cubic inch small block Chevy [Re: TheOtherDodge] #1771078
03/04/15 04:39 PM
03/04/15 04:39 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I love the development thats going on. No matter if its a bow tie, blue oval or cute little red ribbons, it's all good. The LS is hot right now, they talk about the coyote, but I still think the Gen III hemi will take off. Especially after the last engine masters. And no thats not a small block, it's a 600ci custom engine.
Re: 600 cubic inch small block Chevy [Re: an8sec70cuda] #1771079
03/04/15 04:56 PM
03/04/15 04:56 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
The car was called the legend killer. There was nothing small about the motor.
Re: 600 cubic inch small block Chevy [Re: Harley] #1771080
03/04/15 07:48 PM
03/04/15 07:48 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
The CFE block retains the standard Chevy bellhousing pattern and 4-bolt steel main caps (stock 400 journal size); plus the familiar horse-collar timing-cover boss/water jacket holes on the front appears similar to the standard small-block. Other features following tradition include standard Chevy engine-mount locations, available distributor accommodation and oil-pan rail dimensions similar to the famed Rocket block, which was an Oldsmobile version of the SBC used in drag racing and provided wider oil pans for stroker clearance and also a raised cam location.
“You can even bolt a regular Chevy water pump to this block,” says Gadette.
Re: 600 cubic inch small block Chevy [Re: dogdays] #1771081
03/04/15 08:26 PM
03/04/15 08:26 PM
Lehigh Acres, Florida
rickstershemi Offline
R.
Well with blocks today capable of 1000+ CI, It sure seems on the small side to me....LOL
At least they did state: "within the somewhat traditional confines of the 58-year-old SBC platform."
Rickster
Re: 600 cubic inch small block Chevy [Re: rickstershemi] #1771082
03/04/15 08:39 PM
03/04/15 08:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If a Mopar big block can't make adequate power with 4.800" bore centers at 600" why would this motor make power at 4.600"?????????????????????
Doug
Re: 600 cubic inch small block Chevy [Re: dvw] #1771083
03/04/15 09:23 PM
03/04/15 09:23 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Cause it's not a Chevy lol! Seriously I was wondering the same thing
Re: 600 cubic inch small block Chevy [Re: dvw] #1771084
03/04/15 09:52 PM
03/04/15 09:52 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Doug
What's "adequate" power. This thing will go to a 4.500 bore. In the "real world", bore for bore, stroke for stroke, assuming heads equal, although the SBX head is a bad biotch, this and a similar constructed Mopar big block SHOULD make about the same power. But here is the kicker, THIS one, because of the "foundation" of the block, gets to run at a smallblock weight break, in a class based on that criteria. Now you can complain all you want, that it is NOT a real smallblock, but according to rules makers it is, because of what it was BASED from.
Re: 600 cubic inch small block Chevy [Re: Monte_Smith] #1771085
03/04/15 10:08 PM
03/04/15 10:08 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
OK nice head. Why can this motor go 4.500" at 4.600" bore C/L? Assuming proper cylinder wall and deck thickness, could you go 4.700" on a 4.800"? Can a KB go 4.700" on standard bore C/L? Am I missing something? Obviously a very thin head gasket area between the cylinders.
Doug
Re: 600 cubic inch small block Chevy [Re: dvw] #1771086
03/04/15 11:22 PM
03/04/15 11:22 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
All we have to do is adapt a 340 water pump to a 426 hemi and it is a SB, quick someone get out their CNC
Re: 600 cubic inch small block Chevy [Re: HotRodDave] #1771087
03/04/15 11:26 PM
03/04/15 11:26 PM
PA.
"Little"John
"Little"John
PA.
That won't help. Most of the 426 Hemi's I see are 9-10 second DOGS. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 600 cubic inch small block Chevy [Re: Harley] #1771088
03/04/15 11:35 PM
03/04/15 11:35 PM
jersey
Spaceman Spiff Offline
jersey
I remember Crunch always trying to set up races with that car on SBP.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 600 cubic inch small block Chevy [Re: Spaceman Spiff] #1771089
03/05/15 12:17 AM
03/05/15 12:17 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
I really don't see why it matter if its small or big ..its a bad mother either way..mopar is never going to step up with anything close ...
Re: 600 cubic inch small block Chevy [Re: earthmover] #1771090
03/05/15 09:27 AM
03/05/15 09:27 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Chevy/GM didn't step up either. CFE did. There's nothing stopping anyone from developing something similar for a Mopar.
