Good aluminum polish and cleaner?
#1768573
03/01/15 07:36 PM
03/01/15 07:36 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I bought a set of polished aluminum wheels that where not hard anadized after the polishing, I think What brand and type of cleaner and or polish do you guys like and use Thanks in advance for any help
Re: Good aluminum polish and cleaner?
[Re: ahy]
#1768575
03/01/15 08:07 PM
03/01/15 08:07 PM
Posts: 4,687 Wichita
GY3
Wichita
[Re: pittsburghracer]
#1768579
03/01/15 09:40 PM
03/01/15 09:40 PM
Posts: 1,552 Michigan
Kiddart
I stop at a truck stops and buy the brands made by Busch's
real easy to use and works awesome
Thank you Kiddart
[Re: rickraw]
#1768580
03/01/15 10:34 PM
03/01/15 10:34 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I tried them all over the years. I like white diamond the best. Advance auto has it. If u ever see the ragman at swap meets, his polish is fantastic.
That cleaner/polish "The Rag Man" has ROCKS
Empty used Pepsi bottle and all
[Re: 1967dartgt]
#1768583
03/02/15 12:23 AM
03/02/15 12:23 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
I use Purple on my semi truck fuel tanks and wheels. I have tried a lot of polishes over the years and have found that Purple holds the shine a little longer when exposed to the elements. They also have a cleaner that is green in color that you use before the polish stage. When the weather breaks I am going to try a new item called Sheen Genie, they have a cleaner as well as the polish.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: roadhazard]
#1768586
03/02/15 11:44 AM
03/02/15 11:44 AM
Posts: 290 Norwalk Ohio
cudasteve68
Norwalk Ohio
His polish works pretty good. The only issue I have with it is that is a chemical that strips the oxidation & does not leave any protection on the wheel. I use Flitz. You can buy it online. Only have to use it one to two times a year. It leaves a protective film, kinda like wax on paint.
[Re: Cab_Burge]
#1768588
03/02/15 10:40 PM
03/02/15 10:40 PM
Posts: 5,107 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Cab...If they're polished up nice already the White Diamond will work good. It leaves a bit of a film behind to help protect it too. If they're still a little rough you may want to use something a little more abrasive.
...FAFO...
