Good aluminum polish and cleaner? #1768573
03/01/15 07:36 PM
03/01/15 07:36 PM
Cab_Burge Offline OP
I bought a set of polished aluminum wheels that where not hard anadized after the polishing, I think What brand and type of cleaner and or polish do you guys like and use Thanks in advance for any help
Re: Good aluminum polish and cleaner? [Re: Cab_Burge] #1768574
03/01/15 07:44 PM
03/01/15 07:44 PM
IN
ahy Offline
ahy  Offline
IN
I usually use Mothers if not too bad. I have also used regular autobody polishing compound on tough spots. There are quite a few other chemical and abrasive options but above has worked for me.
Re: Good aluminum polish and cleaner? [Re: ahy] #1768575
03/01/15 08:07 PM
03/01/15 08:07 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mothers.
Re: Good aluminum polish and cleaner? [Re: GY3] #1768576
03/01/15 08:19 PM
03/01/15 08:19 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
I tried them all over the years. I like white diamond the best. Advance auto has it. If u ever see the ragman at swap meets, his polish is fantastic.
Re: Good aluminum polish and cleaner? [Re: rickraw] #1768577
03/01/15 08:43 PM
03/01/15 08:43 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Go to your local truck stop pick up a bar of polish best I have used..I use it on my dump trucks wheels and tank and have tried many but they seem to work the best..they come in many type of cuts just read the sign figure which is best for your wheels
Re: Good aluminum polish and cleaner? [Re: earthmover] #1768578
03/01/15 08:59 PM
03/01/15 08:59 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Good aluminum polish and cleaner? [Re: pittsburghracer] #1768579
03/01/15 09:40 PM
03/01/15 09:40 PM
K
Kiddart Offline
Kiddart  Offline
K
I stop at a truck stops and buy the brands made by Busch's
real easy to use and works awesome
Thank you
Kiddart
Re: Good aluminum polish and cleaner? [Re: rickraw] #1768580
03/01/15 10:34 PM
03/01/15 10:34 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
That cleaner/polish "The Rag Man" has ROCKS
Empty used Pepsi bottle and all
Re: Good aluminum polish and cleaner? [Re: Cab_Burge] #1768581
03/01/15 11:06 PM
03/01/15 11:06 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Brasso and a microfiber cloth works good as well.
Re: Good aluminum polish and cleaner? [Re: pittsburghracer] #1768582
03/02/15 12:04 AM
03/02/15 12:04 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Lots of guys like this stuff.
http://www.speedymetalpolish.com/products.html
Love this stuff.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Good aluminum polish and cleaner? [Re: 1967dartgt] #1768583
03/02/15 12:23 AM
03/02/15 12:23 AM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I use Purple on my semi truck fuel tanks and wheels. I have tried a lot of polishes over the years and have found that Purple holds the shine a little longer when exposed to the elements. They also have a cleaner that is green in color that you use before the polish stage. When the weather breaks I am going to try a new item called Sheen Genie, they have a cleaner as well as the polish.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Good aluminum polish and cleaner? [Re: G-Money1320] #1768584
03/02/15 12:43 AM
03/02/15 12:43 AM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
The guy that details the trucks at the Kenworth dealer where I work, swears by "MOJO" polish.
"I've upped my horsepower, so...... UP YOURS!!!"
Re: Good aluminum polish and cleaner? [Re: DusterDog] #1768585
03/02/15 01:22 AM
03/02/15 01:22 AM
new york usa
P
pattyboy 572 Offline
P
new york usa
X2 on mojo
Re: Good aluminum polish and cleaner? [Re: roadhazard] #1768586
03/02/15 11:44 AM
03/02/15 11:44 AM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
His polish works pretty good. The only issue I have with it is that is a chemical that strips the oxidation & does not leave any protection on the wheel. I use Flitz. You can buy it online. Only have to use it one to two times a year. It leaves a protective film, kinda like wax on paint.
Re: Good aluminum polish and cleaner? [Re: Cab_Burge] #1768587
03/02/15 04:17 PM
03/02/15 04:17 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
Everybody has their favorite; mine is simichrome, works better than the others I have tried.
Re: Good aluminum polish and cleaner? [Re: Cab_Burge] #1768588
03/02/15 10:40 PM
03/02/15 10:40 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Cab...If they're polished up nice already the White Diamond will work good. It leaves a bit of a film behind to help protect it too.
If they're still a little rough you may want to use something a little more abrasive.
...FAFO...
Re: Good aluminum polish and cleaner? [Re: skicker] #1768589
03/03/15 12:48 AM
03/03/15 12:48 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
White Diamond works great.
Nautilus Racing-
