1970 Cuda Variable Speed Wiper Transmission #1765482
02/28/15 08:43 PM
02/28/15 08:43 PM
Arkansas
N
Nimbus426 Offline OP
N
Arkansas
Hey there, I am finally trying to get my wipers working, but I'm not sure if I have the right parts. I have a 3 speed or variable speed motor, I'm trying to figure out if my transmission is for a 2 speed or a variable speed because the end of it extends about 1-1/2" - 2" past the back of the motor (see attached pics). Am I missing a part to connect the transmission arm to the motor? Thanks in advance.
-ERIC
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: Nimbus426] #1765483
02/28/15 08:44 PM
02/28/15 08:44 PM
Arkansas
N
N
Arkansas
Here is the part # on the transmission arm
-ERIC
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: Nimbus426] #1765484
02/28/15 08:46 PM
02/28/15 08:46 PM
Colorado
spk2go Online content
spk2go  Online Content
Colorado
Looks like your transmission linkage is for a two speed motor.
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: spk2go] #1765485
02/28/15 08:51 PM
02/28/15 08:51 PM
Arkansas
N
N
Arkansas
Do you know what the number should be for a variable speed?
-ERIC
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: Nimbus426] #1765486
02/28/15 08:54 PM
02/28/15 08:54 PM
Colorado
Colorado
If I remember right its 293 not 292
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: spk2go] #1765487
02/28/15 08:55 PM
02/28/15 08:55 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
You need a 2822293 linkage arm and a 2822289 wiper link.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: VCODE] #1765488
02/28/15 09:05 PM
02/28/15 09:05 PM
Arkansas
N
N
Arkansas
Oh okay. I found two on ebay that claim to be 70 cuda 3 speed transmission arms but they read 2822-291-58622. How does the correct arm connect to the back of the motor?
-ERIC
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: Nimbus426] #1765489
02/28/15 09:09 PM
02/28/15 09:09 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
The link (2822289) is attached to the wiper with a nut. The link has a stud where the linkage (2822293)is attached with a spring washer and lock retainer. Bob
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: VCODE] #1765490
02/28/15 09:14 PM
02/28/15 09:14 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
2
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: VCODE] #1765491
02/28/15 09:15 PM
02/28/15 09:15 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
3
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: VCODE] #1765492
02/28/15 09:56 PM
02/28/15 09:56 PM
Arkansas
N
N
Arkansas
Oh great thank you for the pictures. So I guess the 282-2291 part I saw on ebay is for a different year model?
-ERIC
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: Nimbus426] #1765493
02/28/15 10:06 PM
02/28/15 10:06 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
The 2822291 is the link that will connect the the left and right pivots. Same on a 2 speed.
The drive linkage is different and the one you need
Bob
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: VCODE] #1765494
03/01/15 02:19 AM
03/01/15 02:19 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
There is also a very thin steel washer and a rubber washer between the crank arm and the linkage arm. I also did a quick look on ebag using "cuda wiper linkage" there are no correct parts for a 70 3sp.
NS1AAR
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: ns1aar] #1765495
03/01/15 02:36 AM
03/01/15 02:36 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
from the (Jan. '72) 1970-71 Parts Catalog:
BARRACUDA & CHALLENGER
2822 289 = CRANK w/PIN, Wiper Drive Variable Speed (same as '71 B-body)
2822 290 = CRANK w/PIN, Wiper Drive 2 Speed (same as '71 B-body)
2822 291 = LINK, Wiper Pivot Connection
2822 292 = LINK, Wiper Drive 2 Speed
2822 293 = LINK, Wiper Drive Variable Speed
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: ns1aar] #1765496
03/01/15 11:04 AM
03/01/15 11:04 AM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
Yes Bruce, very hard to find. No one making them.
Bob
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: VCODE] #1765497
03/01/15 05:03 PM
03/01/15 05:03 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Bob
The rubber one is a home depot item in the hardware isle. They are in the pull out bins. In SOCAL they are Everbilt Neopren Washer 3/8 x 13/16 dia the skew #887480157581. If you happen to have any E-body wiper transmissions around there are several installed in them.
NS1AAR
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: ns1aar] #1765498
03/04/15 04:05 AM
03/04/15 04:05 AM
Arkansas
N
N
Arkansas
Thanks for all the help guys!
-ERIC
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: Nimbus426] #1765499
03/05/15 04:32 AM
03/05/15 04:32 AM
Arkansas
N
N
Arkansas
Is there any way to get a 71-74 wiper linkage to work on a 70? Are they the same length?
-ERIC
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: Nimbus426] #1765500
03/05/15 04:44 AM
03/05/15 04:44 AM
Arkansas
N
N
Arkansas
Or I guess it would be 72-74?
-ERIC
Re: 1970 Cuda Variable Speed Wiper Transmission [Re: 6bblgt] #1765501
03/05/15 06:24 AM
03/05/15 06:24 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
not sure what is different besides the part numbers
from the (Nov. '71) 1972 Parts Catalog & (Sept. '72) 1973 Parts Catalog:
23-67-76
3431 518 = CRANK w/PIN, Wiper Drive Variable Speed
3431 553 = CRANK w/PIN, Wiper Drive 2 Speed (same as '72/'73 B-body)
23-67-79
2822 291 = LINK, Wiper Pivot Connecting
3431 514 = LINK, Wiper Drive Variable Speed
