1970 Cuda Variable Speed Wiper Transmission
#1765482
02/28/15 08:43 PM
02/28/15 08:43 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Hey there, I am finally trying to get my wipers working, but I'm not sure if I have the right parts. I have a 3 speed or variable speed motor, I'm trying to figure out if my transmission is for a 2 speed or a variable speed because the end of it extends about 1-1/2" - 2" past the back of the motor (see attached pics). Am I missing a part to connect the transmission arm to the motor? Thanks in advance.
-ERIC
Re: 1970 Cuda Variable Speed Wiper Transmission
[Re: Nimbus426]
#1765483
02/28/15 08:44 PM
02/28/15 08:44 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Here is the part # on the transmission arm
-ERIC
[Re: spk2go]
#1765487
02/28/15 08:55 PM
02/28/15 08:55 PM
Posts: 2,379 White Plains, NY
VCODE
White Plains, NY
You need a 2822293 linkage arm and a 2822289 wiper link. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#1765488
02/28/15 09:05 PM
02/28/15 09:05 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Oh okay. I found two on ebay that claim to be 70 cuda 3 speed transmission arms but they read 2822-291-58622. How does the correct arm connect to the back of the motor?
-ERIC
[Re: Nimbus426]
#1765489
02/28/15 09:09 PM
02/28/15 09:09 PM
VCODE
White Plains, NY
The link (2822289) is attached to the wiper with a nut. The link has a stud where the linkage (2822293)is attached with a spring washer and lock retainer. Bob
[Re: VCODE]
#1765492
02/28/15 09:56 PM
02/28/15 09:56 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Oh great thank you for the pictures. So I guess the 282-2291 part I saw on ebay is for a different year model?
-ERIC
[Re: VCODE]
#1765497
03/01/15 05:03 PM
03/01/15 05:03 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
There is also a very thin steel washer and a rubber washer between the crank arm and the linkage arm. I also did a quick look on ebag using "cuda wiper linkage" there are no correct parts for a 70 3sp.
Yes Bruce, very hard to find. No one making them. Bob
The rubber one is a home depot item in the hardware isle. They are in the pull out bins. In SOCAL they are Everbilt Neopren Washer 3/8 x 13/16 dia the skew #887480157581. If you happen to have any E-body wiper transmissions around there are several installed in them.
NS1AAR
[Re: ns1aar]
#1765498
03/04/15 04:05 AM
03/04/15 04:05 AM
Posts: 104 Arkansas
Nimbus426
Arkansas
Thanks for all the help guys!
-ERIC
[Re: Nimbus426]
#1765499
03/05/15 04:32 AM
03/05/15 04:32 AM
Posts: 104 Arkansas
Nimbus426
Arkansas
Is there any way to get a 71-74 wiper linkage to work on a 70? Are they the same length?
-ERIC
[Re: 6bblgt]
#1765501
03/05/15 06:24 AM
03/05/15 06:24 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
not sure what is different besides the part numbers from the (Nov. '71) 1972 Parts Catalog & (Sept. '72) 1973 Parts Catalog: BARRACUDA & CHALLENGER23-67-763431 518 = CRANK w/PIN, Wiper Drive Variable Speed 3431 553 = CRANK w/PIN, Wiper Drive 2 Speed (same as '72/'73 B-body) 23-67-792822 291 = LINK, Wiper Pivot Connecting 2822 292 = LINK, Wiper Drive 2 Speed 3431 514 = LINK, Wiper Drive Variable Speed
