street dominator vs street master #1763489
02/26/15 12:21 PM
02/26/15 12:21 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
just out of couriosity searching for opinions and experience. They look to be the same ( well, allmost ), with the advantage streetmaster gets the vacuum port and EGR locations same than stock
what you read on title
single choice
Votes accepted starting: 02/26/15 10:21 AM
You must vote before you can view the results of this poll.
Re: street dominator vs street master [Re: NachoRT74] #1763490
02/26/15 12:29 PM
02/26/15 12:29 PM
Valencia, España
Valencia, España
Holley:
Edelbrock:
Re: street dominator vs street master [Re: NachoRT74] #1763491
02/26/15 12:34 PM
02/26/15 12:34 PM
dogdays Offline
dogdays  Offline
NO they are not the same. They were produced by competing companies. Of the two, the Holley Street Dominator was the better manifold. For whatever reason the Streetmaster was allowed to die and was replaced by the original Performer. The Holley Street Dominator is still in production and is a better intake than the Performer as well.
R.
Re: street dominator vs street master [Re: dogdays] #1763492
02/26/15 12:40 PM
02/26/15 12:40 PM
Valencia, España
Valencia, España
well, yes, on pics definitelly the SM seems to get smaller runners... and shorter ( curvature makes longer on SD )
Re: street dominator vs street master [Re: NachoRT74] #1763493
02/26/15 12:59 PM
02/26/15 12:59 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
The Holley Street Dominator always does well across the board when compared to even the high rise single planes. Great all around street/strip manifold that isn't obnoxiously tall.
Re: street dominator vs street master [Re: NachoRT74] #1763494
02/26/15 01:42 PM
02/26/15 01:42 PM
The SM has small restricted ports intended for a low RPM torque build to generate high intake mixture velocity such as in a hauling truck & give a mileage bennie also. It's a 70's item that never really caught on. The SD as said is a pretty good performance intake
Re: street dominator vs street master [Re: RapidRobert] #1763495
02/26/15 01:45 PM
02/26/15 01:45 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
x99 and also on a 100% tow vehicle that is lower rpm ... the SP2P is even bester !
Re: street dominator vs street master [Re: RapidRobert] #1763496
02/26/15 01:45 PM
02/26/15 01:45 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
SD, just looking at the 2 pictures there appears to be more flow into the runners, the SM has more harsh corners.
Careful, your character's showing!
Re: street dominator vs street master [Re: mopar346] #1763497
02/26/15 07:46 PM
02/26/15 07:46 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Back in the day...... When Ey got into the intake game they were very angry and made sure there work was top of the line top notch stuff. There intakes were the best period. No question.
The Street Dom. Also has built in damns in front of some runners.
Re: street dominator vs street master [Re: Rob C] #1763498
02/26/15 08:53 PM
02/26/15 08:53 PM
Who is Ey? The Edlbrock intakes that didn't work very well, the Mopar BB SP2P and the Street Masters, didn't sell very well so Eddy quit making and selling them The federal govts. intervention on smog rules starting in the early 1970s made a lot of after market companys quit making a lot of decent as well as some not so good hot rod parts back then That and the increase price of fuels starting back in the mid 1970s and on
Re: street dominator vs street master [Re: Cab_Burge] #1763499
02/27/15 01:45 PM
02/27/15 01:45 PM
Valencia, España
Valencia, España
Ok, NOW:
COMPAIRING the Eddy SM against the stock one and the Eddy Performer ( not the RPM )
your thoughts
Re: street dominator vs street master [Re: NachoRT74] #1763500
02/27/15 01:53 PM
02/27/15 01:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Comparing the Street Master to the Street Dominator is like comparing an F18 to a Piper Cub. Which one is better? Depends on what you are doing with it.
Yeah they are both airplanes but their design criteria is miles apart. The SM is designed for low rpm high torque and fuel economy. The SM is for the exact opposite. Which one is better? See above.
If you already have a stock intake, run it. The SM or the Performer will not improve upon it other than in weight. If you need to buy an intake go with the Performer unless you get a good price on a stock intake. Pass on the SM unless it is free.
Don't be the exception.
Re: street dominator vs street master [Re: Supercuda] #1763501
02/27/15 08:28 PM
02/27/15 08:28 PM
dogdays Offline
dogdays  Offline
The Performer is a stock replacement intake.
that doesn't mean that it is equivalent to a stock intake. I'm sure Edelbrock could show you a dyno chart from a nearly stock 440 and probably a 20hp increase with the Performer.
I run a Performer on a 400 ford in my $500 truck and it works really well.
R.
Re: street dominator vs street master [Re: dogdays] #1763502
02/27/15 09:38 PM
02/27/15 09:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, I saw zero difference between a Performer and a stock 4bbl intake on a mild 360. So if there is a dyno chart showing 20 hp gain with no other changes I'll call BS.
Re: street dominator vs street master [Re: Supercuda] #1763503
02/27/15 10:08 PM
02/27/15 10:08 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
The SB Performer has 318 sized ports. Dulcich did a dyno test on a mild 360 and the stock intake made a few more hp. I've never seen a Performer 383 or 440 vs a stock intake test .
Re: street dominator vs street master [Re: dogdays] #1763504
02/27/15 10:21 PM
02/27/15 10:21 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
R.
The Street Dominator is no longer made for B engines. They bring good money used. I bought an RPM for less than I could find a SD for my low deck
Re: street dominator vs street master [Re: Dcuda69] #1763505
02/28/15 01:16 PM
02/28/15 01:16 PM
dogdays Offline
dogdays  Offline
B intakes and RB intakes are different enough that one cannot use the RB pecking order to choose a B intake manifold.
Perf RPM is always a good choice.
The Torker383 came out top or very near the top in Dulcich's 383 intake test. I bought mine for $50.00.
R.
