street dominator vs street master
#1763489
02/26/15 12:21 PM
02/26/15 12:21 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
just out of couriosity searching for opinions and experience. They look to be the same ( well, allmost ), with the advantage streetmaster gets the vacuum port and EGR locations same than stock
Re: street dominator vs street master
[Re: dogdays]
#1763492
02/26/15 12:40 PM
02/26/15 12:40 PM
NachoRT74
Valencia, España
well, yes, on pics definitelly the SM seems to get smaller runners... and shorter ( curvature makes longer on SD )
[Re: NachoRT74]
#1763494
02/26/15 01:42 PM
02/26/15 01:42 PM
RapidRobert
The SM has small restricted ports intended for a low RPM torque build to generate high intake mixture velocity such as in a hauling truck & give a mileage bennie also. It's a 70's item that never really caught on. The SD as said is a pretty good performance intake
[Re: RapidRobert]
#1763495
02/26/15 01:45 PM
02/26/15 01:45 PM
Posts: 30,464 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
x99 and also on a 100% tow vehicle that is lower rpm ... the SP2P is even bester !
[Re: Cab_Burge]
#1763499
02/27/15 01:45 PM
02/27/15 01:45 PM
NachoRT74
Valencia, España
Ok, NOW:
COMPAIRING the Eddy SM against the stock one and the Eddy Performer ( not the RPM )
your thoughts
[Re: NachoRT74]
#1763500
02/27/15 01:53 PM
02/27/15 01:53 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Comparing the Street Master to the Street Dominator is like comparing an F18 to a Piper Cub. Which one is better? Depends on what you are doing with it.
Yeah they are both airplanes but their design criteria is miles apart. The SM is designed for low rpm high torque and fuel economy. The SM is for the exact opposite. Which one is better? See above.
If you already have a stock intake, run it. The SM or the Performer will not improve upon it other than in weight. If you need to buy an intake go with the Performer unless you get a good price on a stock intake. Pass on the SM unless it is free.
[Re: dogdays]
#1763502
02/27/15 09:38 PM
02/27/15 09:38 PM
Supercuda
About to go away
About to go away
up yours
Well, I saw zero difference between a Performer and a stock 4bbl intake on a mild 360. So if there is a dyno chart showing 20 hp gain with no other changes I'll call BS.
[Re: Supercuda]
#1763503
02/27/15 10:08 PM
02/27/15 10:08 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
The SB Performer has 318 sized ports. Dulcich did a dyno test on a mild 360 and the stock intake made a few more hp. I've never seen a Performer 383 or 440 vs a stock intake test .
[Re: dogdays]
#1763504
02/27/15 10:21 PM
02/27/15 10:21 PM
Posts: 4,956 WI
Dcuda69
WI
NO they are not the same. They were produced by competing companies. Of the two, the Holley Street Dominator was the better manifold. For whatever reason the Streetmaster was allowed to die and was replaced by the original Performer. The Holley Street Dominator is still in production and is a better intake than the Performer as well.
R.
The Street Dominator is no longer made for B engines. They bring good money used. I bought an RPM for less than I could find a SD for my low deck
