spring upgrading plans #1762370
02/25/15 12:04 AM
02/25/15 12:04 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
So i was planning out my spring upgrades and had a few questions
Has anybody ran a champion radiator for a dodge truck? hows the quality on them? do they mount in the factory spot? trans cooler?
Should i upgrade from the larger summit cam to a hughes whiplash cam? if i do upgrade the cam what else should i order besides lifters?
Aluminum water pump suggestions?
Re: spring upgrading plans [Re: 72d100] #1762371
02/28/15 04:23 PM
02/28/15 04:23 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
Anybody?
Re: spring upgrading plans [Re: 72d100] #1762372
02/28/15 08:53 PM
02/28/15 08:53 PM
IN
ahy Offline
ahy  Offline
IN
On the cam, it depends on the rest of the combo... and how you like the one you have. Compression, intake/carb, exhaust, rear gear ratio and tire diameter. How does it run with the current cam? In general, cam and springs need to be matched so cam change may require springs depending on what you have to start with.
On the Champion rad, I've never run one but they are pretty poplar on brand F PU's. Is the current radiator getting feeble?
If it runs/cools OK now, those upgrades sound like a lot of money and work for moderate gain.
Re: spring upgrading plans [Re: 72d100] #1762373
02/28/15 11:43 PM
02/28/15 11:43 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
you don't mention what engine you have, and what's been done to it. whiplash is a cool cam, but you'll likely need springs to go with it, and you may have to cut the spring seats, as well.
what else? headers, air gap intake, 4 bbl carb, good dizzie and ignition box, etc. 4:10 sure grip also helps. a lot.
Re: spring upgrading plans [Re: Golden-Arm] #1762374
03/01/15 12:12 AM
03/01/15 12:12 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
It's a 400. I don't believe I forgot to mention that The motor has long tube headers a edelebrock dp4b intake and 600 carb. the bottom end is fairly fresh re ringed in 09. Not sure how cool or warm it runs the temp gauge quit working
Re: spring upgrading plans [Re: 72d100] #1762375
03/16/15 12:17 AM
03/16/15 12:17 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
i was looking at my truck today and notice my water pump is backward of all the aluminum aftermarkets ive seen. if i switch to the other side is there a radiator i can swap in that fits?
Re: spring upgrading plans [Re: 72d100] #1762376
03/17/15 03:25 PM
03/17/15 03:25 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
If your talking about buying an aluminum pump housing, maybe one of these will save you the cost of a radiator.
http://store.440source.com/Water-Pump-Housings/products/71/
Re: spring upgrading plans [Re: Jwilli500] #1762377
03/17/15 03:32 PM
03/17/15 03:32 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I bought one of these passenger side drop housings recently, fits nice and it looks to be a great upgrade over the stock one.
Re: spring upgrading plans [Re: CTD5.9] #1762378
03/17/15 11:11 PM
03/17/15 11:11 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
i was planning on useing a champion radiatior anyways. i think mine is a little on the small side
