SLick balancing question #1757955
02/18/15 07:05 PM
02/18/15 07:05 PM
Brea, Ca
Dart Racer Offline OP
Brea, Ca
Are your slicks dynamic balanced or bubble balanced?
Re: SLick balancing question [Re: Dart Racer] #1757956
02/18/15 07:08 PM
02/18/15 07:08 PM
Az
Crizila Offline
Crizila  Offline
Az
bubble.
Fastest 300
Re: SLick balancing question [Re: Crizila] #1757957
02/18/15 07:37 PM
02/18/15 07:37 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Not balanced.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: SLick balancing question [Re: 1967dartgt] #1757958
02/18/15 08:05 PM
02/18/15 08:05 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I've done both, MT and GoodYear vendors at the track will tell you the only way to balance them is with bubble balance.
I bought one from Harbor Freight and it works pretty good.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: SLick balancing question [Re: Dart Racer] #1757959
02/18/15 08:38 PM
02/18/15 08:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to have them dynamic balanced then I bought a
bubble balancer and do my own bubble balancing
Re: SLick balancing question [Re: WadeMetzinger] #1757960
02/18/15 09:56 PM
02/18/15 09:56 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Is this the one?
http://www.harborfreight.com/portable-wheel-balancer-39741.html
Re: SLick balancing question [Re: 451Cuda] #1757961
02/18/15 10:33 PM
02/18/15 10:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Is this the one?
Yep and if you take the time to set it up right and read the feedback on Harbor Freights site works GREAT. I also have a 500 dollar bubble balancer but couldn't use it with my new wheels so I bought one of these.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SLick balancing question [Re: Dart Racer] #1757962
02/18/15 11:03 PM
02/18/15 11:03 PM
Brea, Ca
Brea, Ca
Thanks guys; bubble is what I was thinking; just wanted to hear it from the guys in the know.....
Re: SLick balancing question [Re: pittsburghracer] #1757963
02/18/15 11:09 PM
02/18/15 11:09 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Static on a spin balancer. I've had good luck with the little Snap On electronic machine that you spin up by hand. Stick on weights on the back, of course. Re-balance after maybe 50 or 60 runs. Makes a difference and it doesn't cost anything but some time.
I have no problem with a bubble machine. Used them for years.
Re: SLick balancing question [Re: pittsburghracer] #1757964
02/18/15 11:11 PM
02/18/15 11:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use a Hunter digital unit it also gives accurate tire circumference measurement and I can tell it where I want the weights and what kind I want to use. It's nice to work at a car dealership that buys good equipment
Gus
64 Plymouth Savoy
Dana 60
Re: SLick balancing question [Re: fourgearsavoy] #1757965
02/19/15 01:11 AM
02/19/15 01:11 AM
Cab_Burge Online work
Cab_Burge  Online Work
I bought a new set of M/T 14x32x15 last year on the way to MATS in Reno at Summits store, I ended up having the Goodyear wholesale wharehouse in Las Vegas mount and balane them. I had planned on buying tubes from the one of tire trucks at the race but I ended up doing the tire swap in the middle of the week instaed of waiting for the MATS race after the Spring Fling four day race. Bottom line is Goodyear told me that they hadn't stocked or sold tubes or inner liners in over 4 yrs I had to have them mounted tubeless, the guy doing the work told me he balanced them at 5.0 lbs of pressure and said that the more pressure you ran in thier brand drag slicks had a influnence on the balancing I bubble balance all the tires I can do myself in my shop I had one new old set of 12.25x31.25x15W #6 Firestones about shake my teeth out at around 75 MPH and agian around 119 MPH before balancing them, I balance all my slicks now
Re: SLick balancing question [Re: Cab_Burge] #1757966
02/19/15 12:04 PM
02/19/15 12:04 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
Bubble balanced and make sure your slicks have very similar roll outs.
Re: SLick balancing question [Re: Chad Bittle] #1757967
02/19/15 12:37 PM
02/19/15 12:37 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Please enlighten me on "roll-outs".
Thanks, Joe
Re: SLick balancing question [Re: jlatessa] #1757968
02/19/15 12:41 PM
02/19/15 12:41 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks, Joe
Hit your wifes sowing box for her tape measure and measure the circumference of each tire - aired up. Should be within 1/2" of one another.
Fastest 300
Re: SLick balancing question [Re: Crizila] #1757969
02/19/15 12:45 PM
02/19/15 12:45 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Thanks Crizila, I kinda figured that's what it was, just wanted to be sure.
Joe
Re: SLick balancing question [Re: jlatessa] #1757970
02/19/15 02:57 PM
02/19/15 02:57 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
So why are you not supposed to dynamic balance them? Mine are dynamic balanced with the sticky weights on the inside. Been to 120 with no noticeable shake
Re: SLick balancing question [Re: GTX MATT] #1757971
02/19/15 03:04 PM
02/19/15 03:04 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
