Re: SLick balancing question
[Re: 1967dartgt]
#1757958
02/18/15 08:05 PM
02/18/15 08:05 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I've done both, MT and GoodYear vendors at the track will tell you the only way to balance them is with bubble balance.
I bought one from Harbor Freight and it works pretty good.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: Dart Racer]
#1757959
02/18/15 08:38 PM
02/18/15 08:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are your slicks dynamic balanced or bubble balanced?
I use to have them dynamic balanced then I bought a bubble balancer and do my own bubble balancing
[Re: pittsburghracer]
#1757963
02/18/15 11:09 PM
02/18/15 11:09 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Static on a spin balancer. I've had good luck with the little Snap On electronic machine that you spin up by hand. Stick on weights on the back, of course. Re-balance after maybe 50 or 60 runs. Makes a difference and it doesn't cost anything but some time.
I have no problem with a bubble machine. Used them for years.
#1757964
02/18/15 11:11 PM
02/18/15 11:11 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I use a Hunter digital unit it also gives accurate tire circumference measurement and I can tell it where I want the weights and what kind I want to use. It's nice to work at a car dealership that buys good equipment Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
