overdrive trans question #1756995
02/17/15 08:32 PM
02/17/15 08:32 PM
Midland,Tx
wyldebill Offline OP
Midland,Tx
looking for some info about the overdrive unit 518,618 ect. will the overdrive unit interchange between all of them? thanks
Re: overdrive trans question [Re: wyldebill] #1756996
02/17/15 08:34 PM
02/17/15 08:34 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
yes rh to rh----but no to re
Re: overdrive trans question [Re: savoy64] #1756997
02/17/15 08:39 PM
02/17/15 08:39 PM
Midland,Tx
Midland,Tx
h=hydraulic e=elecrtic? what were either avalable in?
Re: overdrive trans question [Re: wyldebill] #1756998
02/17/15 09:46 PM
02/17/15 09:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Trucks/vans only. Prior to '96 is RH, '96 and later is RE. RH is preferred for retrofits.
Re: overdrive trans question [Re: John_Kunkel] #1756999
02/19/15 12:53 AM
02/19/15 12:53 AM
Midland,Tx
Midland,Tx
So what is the the nomenclature of the last rh?
Re: overdrive trans question [Re: wyldebill] #1757000
02/19/15 01:05 AM
02/19/15 01:05 AM
smyrna,tn
draginmopars Offline
smyrna,tn
RH
Rear wheel drive
Hydraulic shifted
RE
Rear wheel drive
Electronic controlled > shifts
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: overdrive trans question [Re: wyldebill] #1757001
02/19/15 01:12 AM
02/19/15 01:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The easy way to spot a RH is the pin count(not the
neutral safety switch plug) but behind the shifter
will be a plug.... you want either a 1 pin or a 3 pin..
the 7 pin is the electrical type that needs the computer..
the 1 pin is just OD and the 3 pin is OD and lock up
Re: overdrive trans question [Re: wyldebill] #1757002
02/19/15 01:22 AM
02/19/15 01:22 AM
smyrna,tn
smyrna,tn
since the topic is
info about the overdrive unit 518,618 >> ect.
Does anyone know if the valve bodys are the same (shift valves/ springs)
Non lock up 518> (gas engine) and
Non lock up 618 (Diesel)
plan is use a JW bell on the 618
change the governor to shift at 4500
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: overdrive trans question [Re: draginmopars] #1757003
02/19/15 01:12 PM
02/19/15 01:12 PM
Midland,Tx
Midland,Tx
thats kinda what im looking at too. i figured the later od unit would be a better(refined) unit. front half being 727, that part is already proven. i was just tring to get an overdrive and lockup to live behind a bb
Re: overdrive trans question [Re: wyldebill] #1757004
02/19/15 02:20 PM
02/19/15 02:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The lock up wont take WOT and the OD really shouldnt
do it either but you can roll into it with no problem...
I like it in my Rampage.. I pretty much just keep
it in OD(I dont have lock up)
Re: overdrive trans question [Re: wyldebill] #1757005
02/19/15 02:39 PM
02/19/15 02:39 PM
smyrna,tn
smyrna,tn
I did find out the valve bodys are the same
So now I can take the next step
interesting article>
Turn your non lockup 518 into a lockup on the cheap
http://www.dieseltruckresource.com/forum...p-cheap-318014/
Am wanting the 618 trans cause it has more clutches and straight cut gears.
I have a 518 but it is lock up trans,
need non lock up > 618, so that I can use a converter I have with anti-balloning plates and better stall
I have an extra bell, but would rather use the one I added the shift linkage and kick-down mount
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: overdrive trans question [Re: draginmopars] #1757006
02/19/15 02:43 PM
02/19/15 02:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I changed my lock up to a non lock up.. just change
the input shaft and the pump... that way I could put
a high stall conv in.. I went with a 5000 stall I had
Re: overdrive trans question [Re: MR_P_BODY] #1757007
02/19/15 06:09 PM
02/19/15 06:09 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
Hey Mike, I have a late 70s 727 lockup tranny that I took on trade that is freshly rebuilt but I would like to use a non lockup convertor I have. Can I just change the input shaft and pump on it and then use my converter?
Re: overdrive trans question [Re: dragnduster] #1757008
02/19/15 06:17 PM
02/19/15 06:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats all I did... basically I changed the pump
forward(pump and input shaft) I could get it cheaper
that way then buying the parts
EDIT
The pump gears have a different tang on the 727 than
the 518 lock up style... so I just bought the 727
stuff
I see you said NON lock up... I'm not sure on the
tangs on those gears but the 727 stuff does work
Re: overdrive trans question [Re: MR_P_BODY] #1757009
02/19/15 06:21 PM
02/19/15 06:21 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
Thanks I will try that with this 727, that will save me getting a core rebuilt for the 440 I am putting in my street car.
Re: overdrive trans question [Re: MR_P_BODY] #1757010
02/19/15 06:33 PM
02/19/15 06:33 PM
smyrna,tn
smyrna,tn
Did you change the valve body?
I have a LU 518
want to change the converter to a 3500 non LU
Was going to pull the Non LU parts from a 618
but then thought to add a bell to it and change the governor weights ?
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: overdrive trans question [Re: draginmopars] #1757011
02/19/15 06:38 PM
02/19/15 06:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a LU 518
No... I kept the stock VB... the 618 VB has the diesel
shift timing(LOW rpm).. all I changed was the pump
and input shaft then did the trans go shift kit
Re: overdrive trans question [Re: MR_P_BODY] #1757012
02/19/15 06:46 PM
02/19/15 06:46 PM
smyrna,tn
smyrna,tn
I have a LU 518
Thats why I'm asking about the valve bodys
Gas vs diesel
Been told the bodys are the same only the governor weights are changed ????
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: overdrive trans question [Re: draginmopars] #1757013
02/19/15 06:52 PM
02/19/15 06:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a LU 518
Gas vs diesel
I kept the stock 518 VB... but the Trans go shift
kit does change a spring or two... works nice.. I
had a issue of the governor sticking so it had to
come out for a good cleaning
Re: overdrive trans question [Re: MR_P_BODY] #1757014
02/19/15 07:41 PM
02/19/15 07:41 PM
Midland,Tx
Midland,Tx
im not trying to run wot in overdrive or lu. is there not a stall converter available for a lu?if not i guess ill look into building a ford trans and controler. i know that i can build a 5r110 to work.
