Re: overdrive trans question
[Re: wyldebill]
#1756998
02/17/15 09:46 PM
02/17/15 09:46 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Trucks/vans only. Prior to '96 is RH, '96 and later is RE. RH is preferred for retrofits.
[Re: wyldebill]
#1757000
02/19/15 01:05 AM
02/19/15 01:05 AM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
RH Rear wheel drive Hydraulic shifted
RE Rear wheel drive Electronic controlled > shifts
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: wyldebill]
#1757001
02/19/15 01:12 AM
02/19/15 01:12 AM
Posts: 52,972 Romeo MI
MR_P_BODY
So what is the the nomenclature of the last rh?
The easy way to spot a RH is the pin count(not the neutral safety switch plug) but behind the shifter will be a plug.... you want either a 1 pin or a 3 pin.. the 7 pin is the electrical type that needs the computer.. the 1 pin is just OD and the 3 pin is OD and lock up
[Re: wyldebill]
#1757004
02/19/15 02:20 PM
02/19/15 02:20 PM
MR_P_BODY
thats kinda what im looking at too. i figured the later od unit would be a better(refined) unit. front half being 727, that part is already proven. i was just tring to get an overdrive and lockup to live behind a bb
The lock up wont take WOT and the OD really shouldnt do it either but you can roll into it with no problem... I like it in my Rampage.. I pretty much just keep it in OD(I dont have lock up)
[Re: wyldebill]
#1757005
02/19/15 02:39 PM
02/19/15 02:39 PM
draginmopars
smyrna,tn
I did find out the valve bodys are the same So now I can take the next step interesting article> Turn your non lockup 518 into a lockup on the cheap http://www.dieseltruckresource.com/forum...p-cheap-318014/ Am wanting the 618 trans cause it has more clutches and straight cut gears. I have a 518 but it is lock up trans, need non lock up > 618, so that I can use a converter I have with anti-balloning plates and better stall I have an extra bell, but would rather use the one I added the shift linkage and kick-down mount
Howard
[Re: draginmopars]
#1757006
02/19/15 02:43 PM
02/19/15 02:43 PM
MR_P_BODY
I changed my lock up to a non lock up.. just change the input shaft and the pump... that way I could put a high stall conv in.. I went with a 5000 stall I had
[Re: MR_P_BODY]
#1757007
02/19/15 06:09 PM
02/19/15 06:09 PM
Posts: 316 Utah
dragnduster
Utah
Hey Mike, I have a late 70s 727 lockup tranny that I took on trade that is freshly rebuilt but I would like to use a non lockup convertor I have. Can I just change the input shaft and pump on it and then use my converter? Thanks
[Re: dragnduster]
#1757008
02/19/15 06:17 PM
02/19/15 06:17 PM
MR_P_BODY
Thats all I did... basically I changed the pump forward(pump and input shaft) I could get it cheaper that way then buying the parts EDIT The pump gears have a different tang on the 727 than the 518 lock up style... so I just bought the 727 stuff I see you said NON lock up... I'm not sure on the tangs on those gears but the 727 stuff does work
[Re: MR_P_BODY]
#1757009
02/19/15 06:21 PM
02/19/15 06:21 PM
Posts: 316 Utah
dragnduster
Utah
Thanks I will try that with this 727, that will save me getting a core rebuilt for the 440 I am putting in my street car.
[Re: draginmopars]
#1757011
02/19/15 06:38 PM
02/19/15 06:38 PM
MR_P_BODY
Did you change the valve body?
I have a LU 518 want to change the converter to a 3500 non LU
Was going to pull the Non LU parts from a 618 but then thought to add a bell to it and change the governor weights ?
No... I kept the stock VB... the 618 VB has the diesel shift timing(LOW rpm).. all I changed was the pump and input shaft then did the trans go shift kit
[Re: draginmopars]
#1757013
02/19/15 06:52 PM
02/19/15 06:52 PM
MR_P_BODY
Thats why I'm asking about the valve bodys
Gas vs diesel
Been told the bodys are the same only the governor weights are changed ????
I kept the stock 518 VB... but the Trans go shift kit does change a spring or two... works nice.. I had a issue of the governor sticking so it had to come out for a good cleaning
