Best way to raise front of car? #175459
12/26/08 05:34 PM
12/26/08 05:34 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I'm moving closer to the point where I'll be taking out my motor from the bottom. I purchased a 2 ton cherry picker, but I'm not sure how to raise the front of the car. Some have suggested using the bumper mounts, not sure which ones or if there's another approach. I might also need help in how to hook up to the cherry picker.
Thanks,
Re: Best way to raise front of car? [Re: 1fastrunner] #175460
12/26/08 06:13 PM
12/26/08 06:13 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Re: Best way to raise front of car? [Re: 68CoronetRT] #175461
12/27/08 12:45 AM
12/27/08 12:45 AM
NM
74fish Offline
74fish  Offline
NM
I used 2 jackstands in the back as a pivot. I balanced it so you can pick up the front by hand. I used a cherry picker and a pallet jack for the engine. The pallet jack was great because it was so low and it was easy to move the engine plus I didn't have to raise the car that high. I used the bumper mounts with chains. You have to position them so you don't hit any part of the front radiator frame. I installed the headers,transmision, alternator and powersteering pump. I lowered the car down and raised the K member with the pallet jack. Done 2 cars this way. Both small blocks and even stored the engine under. The pallet jack is the best....
Re: Best way to raise front of car? [Re: 74fish] #175462
12/28/08 09:02 PM
12/28/08 09:02 PM
Thanks for the replies!
But, you can't be the only ones doing this....
Re: Best way to raise front of car? [Re: 1fastrunner] #175463
12/28/08 09:08 PM
12/28/08 09:08 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I did it on a couple of cars side by side at the same time...and I went around the core support areas. (they where not Mopars, but Holdens..and done the same way basically with a K frame that drops out with all the suspension)
The bracket bolted to the bumper mounts would be another great way to go and nice and solid. Might be a little harder with yours and the odd shaped bumper
Might see if there is a way to grab from the bumper bracket areas perhaps without hitting the front valance or stone tray
I did a Dart ages ago too now that I think of it, think I went off the bumper area back then too
Re: Best way to raise front of car? [Re: 1fastrunner] #175464
12/29/08 09:49 AM
12/29/08 09:49 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
I installed mine from the bottom. I used the mounts from the rottiserie bolted to my front bumper mounts to pick up the car. I used a cherry picker To lift the front, then put jack stands under the frame rails. Then I connected the picker to the motor. I rolled the motor and tranny under the car with a atv jack and a floor jack under the tranny.
There are picture on the site in my signature. Look under motor and install.
Hope this helped a little, good luck
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: Best way to raise front of car? [Re: 1fastrunner] #175465
12/29/08 10:05 AM
12/29/08 10:05 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Installing the drivetrain from the bottom sure seemed appealing to me at first too, so I was going to try to install-it-from-the-bottom on my 1970. I had never done it before, and decided I didn't have a way to lift the motor & K-frame up to put in the 4 K-frame bolts ect without making or buying something like a dolly or a pallet jack. in the end I decided to go with what I know, so I just used the traditional drop-from-the-top method.
I had the clutch, scattershield, and water pump already installed on my 440 when I dropped it in. There was about 3/4 of an inch extra clearance as it went in, the front suspension and brakes were all in and done and the transmission was easy to put in with a floorjack.
I have done it this way many times in the past, and was familiar with doing it this way by myself. The main reason I considered doing it from the bottom in the first place was because I was concerned that I may scratch up something and it looked so easy, which I'm sure it is if you have the right equiptment.
To overcome my concern about scratching anything, I layed bubble wrap and then cardboard around the engine compartment and used wire to hang my headers in place before putting in the engine. It was easier for me, and I didn't scratch anything.
Re: Best way to raise front of car? [Re: moepwr] #175466
12/29/08 08:44 PM
12/29/08 08:44 PM
I'm guessing I need to remove my bumper to raise the front of the car?
Re: Best way to raise front of car? [Re: 1fastrunner] #175467
12/30/08 11:02 AM
12/30/08 11:02 AM
None
71rm23 Offline
71rm23  Offline
None
And valence
Re: Best way to raise front of car? [Re: 1fastrunner] #175468
12/30/08 11:47 AM
12/30/08 11:47 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You have posted before about this subject, many people responded. Did'nt many people offer suggestions? Why post again?
Re: Best way to raise front of car? [Re: 1fastrunner] #175469
12/30/08 02:35 PM
12/30/08 02:35 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
No. I plan on doing the install on my '72 RR the same way.
Place the rear jack stands at the front spring hanger brackets (shown below). Remove the rear wheels so you can hinge the car up sufficiently without putting weight on the rear axle. Place a couple hundred pounds on the trunk (I used a couple of those 68 pound cement blocks from Home Depot for building garden walls - wrapped in plastic bags, placed in the trunk on carpet scraps.)
Even with the front bumper on, hood on, and interior (including seats) in, I can lift the front of the car by hand at the front bumper. The plan is to have a buddy come over to lift the car up while I roll the k-frame/engine/trans on the dolly underneath the car.
A pic of the placement of the rear jack stands.
Re: Best way to raise front of car? [Re: MoparMarq] #175470
12/30/08 03:50 PM
12/30/08 03:50 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Here's how I did mine:
The bracket just bolts to the bumper mounting points, and worked great as far as making it super easy to do the install. The only down side was that I probably spent 8 hours fabricating it. It's adjustable, though, so I hope to use it on the Coronet when I get to that car.
Re: Best way to raise front of car? [Re: Challenger 1] #175471
12/30/08 09:44 PM
12/30/08 09:44 PM
Sorry Gary,
I'm still looking for more information. This is a big deal to me and I want to be sure to cover all the bases. I will be asking more questions as I get closer to be sure i do things the best way. The more I ask, and I'm sure it's the same for you, the more answers I get. Some people are very creative and I'm sure there's other ideas out there. I saw your version, but I don't have the lift you have so I need some alternatives.
