Page 2 of 3 1 2 3
Re: Tire Size for 1970 Plymouth GTX [Re: gtx6970] #1754488
02/19/15 02:18 PM
02/19/15 02:18 PM
france
jose jones Offline
jose jones  Offline
france
225-70-14 will fit stock 14" factory wheels just fine.
But like mentioned get lost under the car.
And No way would I put a 60 series 14" tire under ,,it looks even worst.
Uping them to a 15" tire is a much better move
IMO
I just put a set of 17x7's and 17x8's on a 68 B-Body for a friend they look really good also
Re: Tire Size for 1970 Plymouth GTX [Re: jose jones] #1754489
02/19/15 03:47 PM
02/19/15 03:47 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
IMO
Pics?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Tire Size for 1970 Plymouth GTX [Re: OzHemi] #1754490
02/21/15 03:22 PM
02/21/15 03:22 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Sorry, that I've asked so many questions about tire size. I bought the rally wheels fifteen years ago and I can't afford to buy new rims and tires so that's why I need to stay with the fourteen inch. I'm going to go with this suggstion. 225 70 14's for the fornt and two 245 60's for the rear. Any last suggestions before I order tires? Thanks for the help.
Re: Tire Size for 1970 Plymouth GTX [Re: GTXKARL] #1754491
02/21/15 03:42 PM
02/21/15 03:42 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
245/60/14s ARE REAL SHORT
245/60/14s DON'T FIT a 14x5.5" wheel very well.
Re: Tire Size for 1970 Plymouth GTX [Re: 6bblgt] #1754492
02/21/15 04:10 PM
02/21/15 04:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not sell the ralley wheels and get some 15" rims and tieres?
Re: Tire Size for 1970 Plymouth GTX [Re: stumpy] #1754493
02/21/15 11:03 PM
02/21/15 11:03 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
One good reason is 14 inch ralleys wont bring any money to speak of.
Careful, your character's showing!
Re: Tire Size for 1970 Plymouth GTX [Re: GTXKARL] #1754494
02/21/15 11:56 PM
02/21/15 11:56 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Wheel Vintiques has 15inch ralleys for about 100 apiece. If you can't afford four new wheels , maybe buy the back ones for now. Small tires on B bodies look awful IMO. http://www.summitracing.com/parts/wvi-56-5812042/overview/ http://www.summitracing.com/parts/wvi-56-5712044/overview/ http://www.summitracing.com/parts/wvi-56-561204/overview/
Re: Tire Size for 1970 Plymouth GTX [Re: forphorty] #1754495
02/22/15 04:58 PM
02/22/15 04:58 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi forphorty.
Thank you for answering my request for help. I'm going to break down and buy the rear wheels from Summit. What is the best size for the back and what size do you think I should get for the front? And what size tires for the front and rear? It's for a 1970 B-Body. Thanks for the help!
Re: Tire Size for 1970 Plymouth GTX [Re: GTXKARL] #1754496
02/22/15 05:51 PM
02/22/15 05:51 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Hi forphorty.
I read the whole post and understand your uncertainty. In your last post that I quoted here it sounds like you are now going to buy some 15x7 Rallyes from Summit. Am I assuming correctly?
Here is my old 70 GTX with 235 60-15 front and 275 60-15 rear. In a perfect world I would have used 245 60-15 for the front but got a deal on these.
If 275 60-15 seems too tall for you then go with 245 60-15 front or rear or 255 60-15 rear.
Hope this helps.
Ron
Re: Tire Size for 1970 Plymouth GTX [Re: RJS] #1754497
02/22/15 06:52 PM
02/22/15 06:52 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
So Ron your saying to get 245- 60-15's for the front? You said to get 275-60-15s for the rear? Are you sure the ones you suggested for the front will work? Futhermore the rim size ...do I get 4 rims that are 15x7? Thanks for your help! Nice Car! Are you anywhere near atco? Karl
Re: Tire Size for 1970 Plymouth GTX [Re: GTXKARL] #1754498
02/22/15 07:49 PM
02/22/15 07:49 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yes 245 60-15 fit without issue, they are the interchange for the factory F 60-15 Bias Ply tire. I prefer 15x7 rims so the trim rings fit correctly and because they are the factory option.
You can put 245 60-15 on rear also to mimic factory size ( F 60-15).
Then I suggested if you thought 275 60-15 was too tall you could also use 255 60-15 on rear.
Here is my other old GTX with Bias Ply GoodYears F 60-15 on 15x7 rims.
I'm less than an hour from Atco.
Ron
Re: Tire Size for 1970 Plymouth GTX [Re: RJS] #1754499
02/22/15 08:30 PM
02/22/15 08:30 PM
france
jose jones Offline
jose jones  Offline
france
So Karl are you sticking to the 14's or did you decide to move up to 15's? IF you go with 15's get 7 inch rims and if you want to rotate them 245-60-15 tires
Re: Tire Size for 1970 Plymouth GTX [Re: GTXKARL] #1754500
02/22/15 08:54 PM
02/22/15 08:54 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I like 275/60s on 15x8 with 4.5 backspace on the back. Looks and fits 68 and up B bodies real well. However, as RJS mentioned, Ive heard that the trim rings don't fit the 15x8 very well, so 15x7 might be a better choice for you.
Re: Tire Size for 1970 Plymouth GTX [Re: forphorty] #1754501
02/22/15 10:17 PM
02/22/15 10:17 PM
mopar346 Offline
mopar346  Offline
If you want bigger rears than front go 275/60s in the back, if you want a square look (stockish) go 245/60s on all 4 corners and you can rotate if you intend to drive it enough to merit that. The 275s will like 8 inch rims much better, a 7 inch rim will work but they balloon a bit and you have to drop the pressure to get them to lay flat and take advantage of all the tread. I have 275s on my AAR on the 7 inch rims, I think I have them at 26 lbs.
Re: Tire Size for 1970 Plymouth GTX [Re: mopar346] #1754502
02/22/15 10:45 PM
02/22/15 10:45 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I always run my tires per the door jam sticker anyway and from memory I believe it is 26lbs.
Here is the same car with 15x7 and 245 60-15 front and back.
Ron
Re: Tire Size for 1970 Plymouth GTX [Re: RJS] #1754503
02/22/15 10:47 PM
02/22/15 10:47 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Okay, everyone thanks for the help! I'm going to put my order in tomorrow to Summit for 4 15 by 7s and where should I get the trim rings from? Because I would like for them to fit correctly. The tire size I'm going to go with is 245 for thre front and275 for the rear. And thanks for all the help. And if anymore suggestions let me know before tomorrow night because that's when I'm putting the order in.
Re: Tire Size for 1970 Plymouth GTX [Re: RJS] #1754504
02/22/15 11:05 PM
02/22/15 11:05 PM
mopar346 Offline
mopar346  Offline
Ron
I agree, but since I rarely running the factory bias plys or the factory size anymore I usually run 32 lbs, front and rear.
Re: Tire Size for 1970 Plymouth GTX [Re: mopar346] #1754505
02/23/15 02:00 AM
02/23/15 02:00 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Helpgtxkarl-any pictures of the 70 GTX?
I've always run 235/70-15 front and 275/60-15 rear. The 235/70 15 is almost as tall as the 275/60-15 being 27.4" diameter vs. 28" diameter.
Re: Tire Size for 1970 Plymouth GTX [Re: Airgrabber] #1754506
02/23/15 02:20 AM
02/23/15 02:20 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
If you're buying the 15x7.0" wheels from Summit, buy the Wheel Vintiques 15x7 polished trim rings also.
Here's 245/60s & 295/50s on 15x7s (I prefer the 275/60s on the rear)
Re: Tire Size for 1970 Plymouth GTX [Re: Airgrabber] #1754507
02/23/15 02:22 AM
02/23/15 02:22 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Another combo that I had for a different look was 295/50-15 on 8"rims rear, and 235/60-15 on 7" rims in front.
Page 2 of 3 1 2 3
