Engine build Dilema... Which way to go????
#1753380
02/12/15 08:28 PM
02/12/15 08:28 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
So I'm ready to take the block to the machine shop. My bore is at 4.1845-4.1855. With that being said. Option #1 A new ring pack costs $1067, and the pistons to go with that have a 4.1745 skirt. The spec says skirt clearance must be min 0.0080 and max of 0.0100 (yeah I know a couple cylinders are at .0110) For this all I need to do is run a hone thru for diamond rings and new bearings. Option #2 open the ring lands up (above mentioned pistons) by Eric at Rebco for $210 buy off the shelf 4.185 rings (.043, .043, 3mm) and throw it back together. JE pistons told me they wouldn't open the lands up, but they said I could do whatever I want. Option #3 I have a new set of pistons, that will require boring to 4.200. I will have to buy a new set of rods $600-$800, Rings $414, and the deck will have to be taken down .0500 Everything will be nice and tight again, but I don't like the idea of milling the deck down on this really expensive block. Option #4 order custom rods ($2488) and run the new pistons with current deck height. Not really cost effective...
Re: Engine build Dilema... Which way to go????
[Re: DemonDust]
#1753381
02/12/15 08:38 PM
02/12/15 08:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On option #2 what are your ring lands now... but this sounds like the quickest/best and cheapest
[Re: MR_P_BODY]
#1753382
02/12/15 08:51 PM
02/12/15 08:51 PM
DemonDust
Menomonee Falls
Currently
Groove width Top .0318 (.81mm) 2nd .0335 (.85mm) Oil .079 (2.01mm)
Distance from deck to first ring .1610
Distance between 1st and 2nd ring .1800
Distance between 2nd and oil .080
[Re: DemonDust]
#1753384
02/12/15 09:20 PM
02/12/15 09:20 PM
MR_P_BODY
Currently
To cut the ring grooves is pretty easy and the small amount wouldnt take much space
[Re: DemonDust]
#1753387
02/12/15 09:50 PM
02/12/15 09:50 PM
MR_P_BODY
Do you think the .001 over max tolerance will be an issue?
No... I know I have gone larger.. no big deal.. and for the money otherwise... it wouldnt happen(for me)
[Re: DemonDust]
#1753390
02/12/15 11:05 PM
02/12/15 11:05 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Well I for one would prefer a nice round bore. Seems you are at the limit or close to it for what those pistons were designed for. I would call Total Seal and see what rings are available for bore sizs in the neighborhood of where you are and go from there. FWIW those tiny rings are probably not what you want in the first place. More for an all NA out every HP counts kinda thing.
[Re: Cab_Burge]
#1753392
02/12/15 11:50 PM
02/12/15 11:50 PM
Al_Alguire
Las Vegas
You could also coat the pistons. But still IMO best to start over with a fresh bore.
[Re: DemonDust]
#1753393
02/13/15 12:10 AM
02/13/15 12:10 AM
MR_P_BODY
I've had pistons coated to .005... that didnt turn out well for me since the coating started coming off in a short period of time... if you knew what the next size ring pack is then a set of custom pistons would work.. but no way would I pay $1000 for rings.. for me a set of all out racing rings are .043 so thats the thinnest I would go... but if the bore is just slightly out of round I'd hone it and run it with machining the ring lands... your not looking for every single HP
[Re: MR_P_BODY]
#1753394
02/13/15 12:13 AM
02/13/15 12:13 AM
Al_Alguire
Las Vegas
Well $1000 for rings is not anything new. In fact twice that is nothing new. These new tiny little rings get real expensive especially in big bores. I paid $1900 for the rings in the 99 Hemi I ran. Pistons were another $2600 but this is 4.700 bore stuff.
[Re: Al_Alguire]
#1753395
02/13/15 12:19 AM
02/13/15 12:19 AM
MR_P_BODY
I'm glad for you Al... not me.. I wont spend that kind of money for a set of rings... OR a set of pistons.. and I have bought plenty of custom pistons.... a race set of rings is .043... I dont need the odd ball stuff
[Re: MR_P_BODY]
#1753396
02/13/15 12:29 AM
02/13/15 12:29 AM
Al_Alguire
Las Vegas
Cost money to make power no way around it. We all have to do what we are comfortable with. In my case I was trying to fly the Mopar flag in the heads up NA world. We won a couple of races and finished 2nd in one sanctioning body and top 10 in the NMCA so I feel I did ok. Was it worth the expense, not sure to be honest.
[Re: Al_Alguire]
#1753397
02/13/15 12:34 AM
02/13/15 12:34 AM
MR_P_BODY
Thats where you and I differ... I am a bracket racer and dont need the big power... I want it to live a long life and be consistent... thats why I build light cars.. easy on parts and goes quick on not a ton of power
[Re: Monte_Smith]
#1753398
02/13/15 12:37 AM
02/13/15 12:37 AM
Posts: 174 Oklahoma
hemiiroc
Oklahoma
The motor is already at pretty much max suggested clearance for the pistons you have............so let me throw another option in there. Hone the block to whatever size gets it clean and straight. Buy a custom piston, for THAT bore size, that fits your current rod length and get the ring pack you WANT.
Monte
X2 ...By far the best thing to do
[Re: MR_P_BODY]
#1753399
02/13/15 12:39 AM
02/13/15 12:39 AM
Al_Alguire
Las Vegas
Well I am a Super Class and bracket racer too. The B1 from the Cuda makes real good power and has over 600 laps on it and can go 170 off the stop. As I say we all have a comfort zone. I prefer to have some MPH on my side in the .90 stuff and that takes HP. I also like to go fast when I can and aint gonna run 7's on 800hp in a door car. The new car is nothing more than a fast bracket car in Top Sportsman. Don't worry I will get old one day and slow down But I understand you message loud and clear. And agree for the average bracket guy an .043 ring is pretty racey
