Engine build Dilema... Which way to go???? #1753380
02/12/15 08:28 PM
02/12/15 08:28 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
So I'm ready to take the block to the machine shop. My bore is at 4.1845-4.1855.
With that being said.
Option #1 A new ring pack costs $1067, and the pistons to go with that have a 4.1745 skirt. The spec says skirt clearance must be min 0.0080 and max of 0.0100 (yeah I know a couple cylinders are at .0110) For this all I need to do is run a hone thru for diamond rings and new bearings.
Option #2 open the ring lands up (above mentioned pistons) by Eric at Rebco for $210 buy off the shelf 4.185 rings (.043, .043, 3mm) and throw it back together. JE pistons told me they wouldn't open the lands up, but they said I could do whatever I want.
Option #3 I have a new set of pistons, that will require boring to 4.200. I will have to buy a new set of rods $600-$800, Rings $414, and the deck will have to be taken down .0500 Everything will be nice and tight again, but I don't like the idea of milling the deck down on this really expensive block.
Option #4 order custom rods ($2488) and run the new pistons with current deck height. Not really cost effective...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Engine build Dilema... Which way to go???? [Re: DemonDust] #1753381
02/12/15 08:38 PM
02/12/15 08:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On option #2 what are your ring lands now... but this
sounds like the quickest/best and cheapest
Re: Engine build Dilema... Which way to go???? [Re: MR_P_BODY] #1753382
02/12/15 08:51 PM
02/12/15 08:51 PM
Menomonee Falls
Menomonee Falls
Currently
Groove width
Top .0318 (.81mm)
2nd .0335 (.85mm)
Oil .079 (2.01mm)
Distance from deck to first ring .1610
Distance between 1st and 2nd ring .1800
Distance between 2nd and oil .080
SDG Motorsports
Re: Engine build Dilema... Which way to go???? [Re: DemonDust] #1753383
02/12/15 08:55 PM
02/12/15 08:55 PM
Menomonee Falls
Menomonee Falls
I should mention option 3 and 4 increase the BW from 1467 to around the 1850 range...
SDG Motorsports
Re: Engine build Dilema... Which way to go???? [Re: DemonDust] #1753384
02/12/15 09:20 PM
02/12/15 09:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Currently
Groove width
Top .0318 (.81mm)
2nd .0335 (.85mm)
Oil .079 (2.01mm)
To cut the ring grooves is pretty easy and the small
amount wouldnt take much space
Re: Engine build Dilema... Which way to go???? [Re: MR_P_BODY] #1753385
02/12/15 09:32 PM
02/12/15 09:32 PM
Menomonee Falls
Menomonee Falls
Do you think the .001 over max tolerance will be an issue?
SDG Motorsports
Re: Engine build Dilema... Which way to go???? [Re: DemonDust] #1753386
02/12/15 09:45 PM
02/12/15 09:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I would go with the new ring grooves.
Re: Engine build Dilema... Which way to go???? [Re: DemonDust] #1753387
02/12/15 09:50 PM
02/12/15 09:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No... I know I have gone larger.. no big deal.. and
for the money otherwise... it wouldnt happen(for me)
Re: Engine build Dilema... Which way to go???? [Re: MR_P_BODY] #1753388
02/12/15 10:14 PM
02/12/15 10:14 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The motor is already at pretty much max suggested clearance for the pistons you have............so let me throw another option in there. Hone the block to whatever size gets it clean and straight. Buy a custom piston, for THAT bore size, that fits your current rod length and get the ring pack you WANT.
Monte
Re: Engine build Dilema... Which way to go???? [Re: Monte_Smith] #1753389
02/12/15 10:58 PM
02/12/15 10:58 PM
Menomonee Falls
Menomonee Falls
Pardon my ignorance, but wouldn't you have to bore the cylinders to get them straight? Or can a hone do that too?
Also if I go to whatever bore cleans up straight, is there a on the shelf ring size close to this bore that won't cost an arm and leg?
I'm not trying to be cheap, I have a lot of upgrades planned this winter and don't want to fall on unexpected costs.
SDG Motorsports
Re: Engine build Dilema... Which way to go???? [Re: DemonDust] #1753390
02/12/15 11:05 PM
02/12/15 11:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I for one would prefer a nice round bore. Seems you are at the limit or close to it for what those pistons were designed for. I would call Total Seal and see what rings are available for bore sizs in the neighborhood of where you are and go from there. FWIW those tiny rings are probably not what you want in the first place. More for an all NA out every HP counts kinda thing.
Re: Engine build Dilema... Which way to go???? [Re: DemonDust] #1753391
02/12/15 11:47 PM
02/12/15 11:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have had custom SB Mopar pistons, not all out race pistons like yours, hard anadized to save them It adds between .0018 to .0025 to the O.D., the ring lands have to be recut also so maybe that is another option If so try calling Embree CO (Aerospace) at 714-546-6907 I always shoot for a perfectly round bore with a torque plate and head gasket I'm going to use on that motor , any decent amchine shop with a Suunen CK10 or later machine can hone any bores straight with the new Diamond stone hones they have now
Re: Engine build Dilema... Which way to go???? [Re: Cab_Burge] #1753392
02/12/15 11:50 PM
02/12/15 11:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You could also coat the pistons. But still IMO best to start over with a fresh bore.
Re: Engine build Dilema... Which way to go???? [Re: DemonDust] #1753393
02/13/15 12:10 AM
02/13/15 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've had pistons coated to .005... that didnt turn
out well for me since the coating started coming off
in a short period of time... if you knew what the next
size ring pack is then a set of custom pistons would
work.. but no way would I pay $1000 for rings.. for
me a set of all out racing rings are .043 so thats
the thinnest I would go... but if the bore is just
slightly out of round I'd hone it and run it with
machining the ring lands... your not looking for
every single HP
Re: Engine build Dilema... Which way to go???? [Re: MR_P_BODY] #1753394
02/13/15 12:13 AM
02/13/15 12:13 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well $1000 for rings is not anything new. In fact twice that is nothing new. These new tiny little rings get real expensive especially in big bores. I paid $1900 for the rings in the 99 Hemi I ran. Pistons were another $2600 but this is 4.700 bore stuff.
Re: Engine build Dilema... Which way to go???? [Re: Al_Alguire] #1753395
02/13/15 12:19 AM
02/13/15 12:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm glad for you Al... not me.. I wont spend that kind
of money for a set of rings... OR a set of pistons..
and I have bought plenty of custom pistons.... a race
set of rings is .043... I dont need the odd ball stuff
Re: Engine build Dilema... Which way to go???? [Re: MR_P_BODY] #1753396
02/13/15 12:29 AM
02/13/15 12:29 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Cost money to make power no way around it. We all have to do what we are comfortable with. In my case I was trying to fly the Mopar flag in the heads up NA world. We won a couple of races and finished 2nd in one sanctioning body and top 10 in the NMCA so I feel I did ok. Was it worth the expense, not sure to be honest.
Re: Engine build Dilema... Which way to go???? [Re: Al_Alguire] #1753397
02/13/15 12:34 AM
02/13/15 12:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats where you and I differ... I am a bracket racer
and dont need the big power... I want it to live a
long life and be consistent... thats why I build light
cars.. easy on parts and goes quick on not a ton of power
Re: Engine build Dilema... Which way to go???? [Re: Monte_Smith] #1753398
02/13/15 12:37 AM
02/13/15 12:37 AM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Monte
X2 ...By far the best thing to do
Re: Engine build Dilema... Which way to go???? [Re: MR_P_BODY] #1753399
02/13/15 12:39 AM
02/13/15 12:39 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I am a Super Class and bracket racer too. The B1 from the Cuda makes real good power and has over 600 laps on it and can go 170 off the stop. As I say we all have a comfort zone. I prefer to have some MPH on my side in the .90 stuff and that takes HP. I also like to go fast when I can and aint gonna run 7's on 800hp in a door car. The new car is nothing more than a fast bracket car in Top Sportsman.
Don't worry I will get old one day and slow down But I understand you message loud and clear. And agree for the average bracket guy an .043 ring is pretty racey
