Page 2 of 3 1 2 3
Re: Big Block Oil Pan For Autocross [Re: Mopar Mitch] #1752604
02/12/15 11:46 PM
02/12/15 11:46 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Another thing that needs addressed is valve cover baffling IMO. ANY aftermarket VC's suck in this dept. Been down that road already....
Mopar to the bone!!!
Re: Big Block Oil Pan For Autocross [Re: 72Swinger] #1752605
02/12/15 11:52 PM
02/12/15 11:52 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I currently have stock stamped covers. I had stamped aluminum moroso covers with no baffles but getting them to seal started to become a pain.
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752606
02/13/15 12:08 AM
02/13/15 12:08 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Stock are the best for baffling. Its an easy thing to take for granted until you start getting into some cornering G's.
Re: Big Block Oil Pan For Autocross [Re: Tomswheels] #1752607
02/13/15 12:15 AM
02/13/15 12:15 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I run a Kevco on my 360, stock size but baffled. I'm not sure if they make a big block one, but they are less expensive than Milodon...
And you have had no pressure drop issues? If so that makes me feel pretty good since I also have a Kevko on my 340. Haven't cornered hard enough yet to find out.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Big Block Oil Pan For Autocross [Re: RylisPro] #1752608
02/13/15 12:47 AM
02/13/15 12:47 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I ordered my pan directly from the manufacturer, it was $380 plus shipping, it was the 31581, had the external oil line....Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Big Block Oil Pan For Autocross [Re: goldduster318] #1752609
02/13/15 03:50 AM
02/13/15 03:50 AM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
No pressure drop yet!
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752610
02/13/15 04:17 AM
02/13/15 04:17 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Milodon 31580 is the road race pan. Its expensive.
Increased capacity with no compromise of ground clearance and gated to keep oil under pickup, what not to like except price?
Answer: Flimsy flange which is prone to severe dimpling when torqued to recommended 15 pounds,,,unless you are a fan of silicone sealers, which I am not,,,,will likely leak if not torqued to that number. Your results may vary depending on gasket supplier.
A bit of 1/8th steel stock and a drill press has addressed this severe design flaw very well for me. No silicone and no leaks.
Re: Big Block Oil Pan For Autocross [Re: Sxrxrnr] #1752611
02/13/15 02:25 PM
02/13/15 02:25 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
X2 on the Milodon pan, IF they have it. Usually they are out of stock....I also sell a one piece plastic/silicone oil pan gasket that has a windage tray built in.
Re: Big Block Oil Pan For Autocross [Re: BergmanAutoCraft] #1752612
02/13/15 11:23 PM
02/13/15 11:23 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
For the 360 guys here is the pan you need. They also make it for 6.1 Hemi, no idea if it also fits 5.7 Hemi
http://www.daileyengineering.com/mopar_360.htm
Re: Big Block Oil Pan For Autocross [Re: PHJ426] #1752613
02/14/15 12:07 AM
02/14/15 12:07 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What? No AMC 390 pan and pumps?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Big Block Oil Pan For Autocross [Re: Skeptic] #1752614
02/14/15 03:03 AM
02/14/15 03:03 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
So are engines-pay me now or pay me MORE later. Here's one in my 68 Barracuda, it's a tight fit in the K, but doesn't hit anything.
I put one in a '68 Barracuda in 2004 w/ a '75 K-frame and had to clearance the K-frame a little. Mine has the 1/2" pick up. The bottom of the pan sits flush with the K-frame, it holds 7 quarts, and has the little trap doors to keep the oil in the pickup area during accel / decel and turns.
Attached picture is the Lokar dipstick fit tested using the 1/2" NPT port on the top of the sump.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Big Block Oil Pan For Autocross [Re: 68cuda440] #1752615
02/14/15 04:12 AM
02/14/15 04:12 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Sweet pics Micheal I have one of my BB 72 A body K member from underneath
Re: Big Block Oil Pan For Autocross [Re: 72Swinger] #1752616
02/14/15 04:16 AM
02/14/15 04:16 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Got one with Gen III too. Its a little more snug to the same K member.
Re: Big Block Oil Pan For Autocross [Re: 72Swinger] #1752617
02/14/15 12:21 PM
02/14/15 12:21 PM
Los Osos, Ca
CKessel Online content
CKessel  Online Content
Los Osos, Ca
The picture of the Lokar stick is similar to what I have to do for the 581 pan. The Indy aluminum block has no provision for a stick. They must figure its not neccessary to keep an eye on the oil level. HMMM! I'll drain the oil out after the unit is mounted in the rh pan bung then mark it starting at 5qts for every quart added so there is at least some refference to go by besides rod knock. I'll also mount the k-frame to it while its on the stand to clearance as needed for the pan, frame reinforcements, headers etc.
Carl Kessel
Re: Big Block Oil Pan For Autocross [Re: 72Swinger] #1752618
02/14/15 02:07 PM
02/14/15 02:07 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Does the 31003 use a specific dipstick? Part number?
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Big Block Oil Pan For Autocross [Re: RylisPro] #1752619
02/14/15 06:24 PM
02/14/15 06:24 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Im just using an ebay special on mine. Gonna have to make another "stick" though out of stainless tig rod because this one reads just barely.
Re: Big Block Oil Pan For Autocross [Re: 68cuda440] #1752620
02/14/15 07:38 PM
02/14/15 07:38 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Mine's in a '68 with a '75 K as well. I trimmed the K when I had it out to reinforce it, so I don't have any data on how it would have fit without that. The K stampings don't seem to have a lot of consistency, so YMMV. I used the Schumaker mounts, I've got a crank scraper, but no windage tray.
Re: Big Block Oil Pan For Autocross [Re: Skeptic] #1752621
02/16/15 01:43 PM
02/16/15 01:43 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
I just called the guys at kevko, they are building my pan to the exact specs I gave them, this is my first big block, but I have like ten of their small block pans, I recommend them highly. I talked to the exact guy building my pan. I like that.
Re: Big Block Oil Pan For Autocross [Re: cageman] #1752622
03/09/15 03:20 PM
03/09/15 03:20 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Small update. I tried mocking up the pan today. Looks like I will have to clearance the kframe.
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752623
03/10/15 11:25 AM
03/10/15 11:25 AM
Los Osos, Ca
Los Osos, Ca
Glad to see you are already at it on the pan! When I start working on mine, I have the luxury of the k-frame is not mounted and the engine is on the stand. Will do the clearance checking without diving under the car.
Carl Kessel
Page 2 of 3 1 2 3
