Page 1 of 3 1 2 3
Big Block Oil Pan For Autocross #1752584
02/12/15 12:03 AM
02/12/15 12:03 AM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I have a 73 Charger with a 440, HV oil pump, windage tray, and 402 oil pan. I am setting up the car for autocross and am worried about starving the engine for oil. As of right now I have crappy all-seasons, Radial TA, on 15" wheels. In the near future I am upgrading to Direzza ZII on 17" wheels. I have 2.45 rear gears currently so I will never have to shift out of 1st at AutoX.
Do I risk losing oil pressure with my current setup?
Do I risk losing oil pressure with the upgraded wheels and tires.
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752585
02/12/15 12:06 AM
02/12/15 12:06 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
yup
oh ya
look on summit web site, and/or that other race parts web site.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Big Block Oil Pan For Autocross [Re: amxautox] #1752586
02/12/15 12:09 AM
02/12/15 12:09 AM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Thank You,
Looks like summit has a $100 6qt hemi repro pan.
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752587
02/12/15 12:12 AM
02/12/15 12:12 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
You need a wide pan that's baffled not a 6 quart stock style pan. Also get an accumulator
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Big Block Oil Pan For Autocross [Re: Jerry] #1752588
02/12/15 12:19 AM
02/12/15 12:19 AM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I assume those will interfere with some headers?
Re: Big Block Oil Pan For Autocross [Re: Jerry] #1752589
02/12/15 12:20 AM
02/12/15 12:20 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Milodon's stock replacement pans have a minimal baffle in them, better than stock but not as pricey as an all out road race pan. How much it helps, I dunno. I usually use that and a windage tray as well as a lifter valley baffle as the extent of my oil control setup, but that is on a smallblock, you don't need the lifter valley baffle on a BB.
An accumulator might be cheap insurance though.
Don't be the exception.
Re: Big Block Oil Pan For Autocross [Re: Supercuda] #1752590
02/12/15 12:26 AM
02/12/15 12:26 AM
amxautox Offline
amxautox  Offline
Milodon
That's the name I couldn't think of. Look on their web site to see what they make.
And the other parts web site. Jegs
Tom
author unknown
Re: Big Block Oil Pan For Autocross [Re: amxautox] #1752591
02/12/15 12:30 AM
02/12/15 12:30 AM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Milodon 31580 is the road race pan. Its expensive.
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752592
02/12/15 12:32 AM
02/12/15 12:32 AM
amxautox Offline
amxautox  Offline
Yes they are, $600 or more. But worth it rather than blowing a motor.
Tom
author unknown
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752593
02/12/15 12:53 AM
02/12/15 12:53 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
For the Milodon 31580 pan you need the 18328 oil pickup about $500 bucks from Summit
Good luck on them being available from Milodon
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Big Block Oil Pan For Autocross [Re: RylisPro] #1752594
02/12/15 09:31 AM
02/12/15 09:31 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
They provide peace of mind, they keep at least a quart trapped at all times. Doubt clearance from headers would be an issue at all. I run a Road Race pan AND an accumulator on my current rendition. Car has REALLY good brakes and REALLY sticky back tires, it corners ok too, at least it used too.....
Mopar to the bone!!!
Re: Big Block Oil Pan For Autocross [Re: 72Swinger] #1752595
02/12/15 10:09 AM
02/12/15 10:09 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I completely agree.
I think it is a good thing that more and more people are ordering these road racing parts.
It may make Milodon consider us Mopar fans profitable instead of just the Ford and GM guys.
Supply and demand
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752596
02/12/15 12:13 PM
02/12/15 12:13 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
So are engines-pay me now or pay me MORE later. Here's one in my 68 Barracuda, it's a tight fit in the K, but doesn't hit anything.
It was leaking from one of the welds, Brian @ IMM epoxyied it up. By the time the engine was on the pump it was out of warranty and I didn't have time to get with them to try and get an exchange.
Re: Big Block Oil Pan For Autocross [Re: Skeptic] #1752597
02/12/15 12:38 PM
02/12/15 12:38 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I have one of those pans plus the 3/8 pickup for it. Was going to use it on the new Indy motor for the car but the Indy came with a revised version of the pan. Its setup for an external pickup now. New pan camping out on the shelf. Any takers? Pm me.
Carl Kessel
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752598
02/12/15 02:47 PM
02/12/15 02:47 PM
Pikes Peak Country
TC@HP2 Online content
TC@HP2  Online Content
Pikes Peak Country
Yes, but $600 is a lot less than an engine rebuild where I live.
You always could get a weld up kit from an oval track supplier and double up on it for both sides of the sump to add capacity and trap doors. Maybe cost you $100 plus time and labor.
Big thing is to keep oil around the pick up. This is why good pans are expensive. They have internal sumps and gates to trap oil around the pick up in specific directions so that there is always oil at the tube.
Re: Big Block Oil Pan For Autocross [Re: TC@HP2] #1752599
02/12/15 04:08 PM
02/12/15 04:08 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Thanks, I decided to buy a Milodon pan before I AutoX it. For now the 944 will have to do.
Has anyone tried to put this pan in a 73+ B-body yet?
Re: Big Block Oil Pan For Autocross [Re: bordin34] #1752600
02/12/15 04:22 PM
02/12/15 04:22 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I run the Milodon Road Race Pan on a '68, never needed an accumulator with this set-up. Plenty of time of the road course.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Big Block Oil Pan For Autocross [Re: Viol8r] #1752601
02/12/15 06:13 PM
02/12/15 06:13 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
I run a Kevco on my 360, stock size but baffled. I'm not sure if they make a big block one, but they are less expensive than Milodon...
Re: Big Block Oil Pan For Autocross [Re: Tomswheels] #1752602
02/12/15 06:38 PM
02/12/15 06:38 PM
AndyF Online content
AndyF  Online Content
Kevko can build big block pans. I have several big block pans from them.
Re: Big Block Oil Pan For Autocross [Re: Tomswheels] #1752603
02/12/15 06:47 PM
02/12/15 06:47 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Its too bad MaMopar never baffled their pans in the first place, E/SPecially for those cars that were marketed for hi-per usage (RT, TA-AAR, etc); the 440-6 and Hemi cars had baffles for acceleration/deceleration, but that alone doesn't do enough for cornering.... but that pan will help the BB engine live longer.
Get the Milodon pan for your BB. On my SB I've welded f/r/side horizontal plates for baffeling (did that ~40 years ago... best mod I've ever done to the car to save the engine!)... I may someday upgrade to the Milodon pan as it appears to be a hi-quality product worht its expense. I advise other people I meet (w/Mopars) that the 1st thing they need to do is modify or change their oil pan to include baffeles.
Page 1 of 3 1 2 3
