Page 1 of 4 1 2 3 4
kaase 820ci mopar hemi #1748264
02/07/15 01:58 AM
02/07/15 01:58 AM
geezer acres rest home
dakotawilly Offline OP
for all the big dog mopar racers out there,kaase 820 cubic inch mopar hemi,5 x 12 billet block,1800 plus horsepower.call for price {sitting down of course}.....
SFI 25.5 depends,no leak,even at 213 mph....
Re: kaase 820ci mopar hemi [Re: dakotawilly] #1748265
02/07/15 06:05 AM
02/07/15 06:05 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
No big deal, just ordered 3 LMAO!!
Re: kaase 820ci mopar hemi [Re: SpareParts] #1748266
02/07/15 10:35 AM
02/07/15 10:35 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you gotta ask how much.........
Re: kaase 820ci mopar hemi [Re: dakotawilly] #1748267
02/07/15 01:29 PM
02/07/15 01:29 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
YEAH!-------------- THAT'LLL fit in an A-body!
Re: kaase 820ci mopar hemi [Re: hemicop] #1748268
02/07/15 01:58 PM
02/07/15 01:58 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Sure will! Who's first?!!
Re: kaase 820ci mopar hemi [Re: Rob C] #1748269
02/07/15 02:15 PM
02/07/15 02:15 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I hope it runs on pump gas!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: kaase 820ci mopar hemi [Re: QTR MILR] #1748270
02/07/15 02:22 PM
02/07/15 02:22 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
That's Killer but twin billlit 88s on anything over 400 CID will make more power.
Re: kaase 820ci mopar hemi [Re: dakotawilly] #1748271
02/07/15 02:44 PM
02/07/15 02:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
So what makes it a Mopar?
Re: kaase 820ci mopar hemi [Re: GY3] #1748272
02/07/15 03:32 PM
02/07/15 03:32 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
It says so on the valve cover,
Re: kaase 820ci mopar hemi [Re: hemicop] #1748273
02/07/15 04:29 PM
02/07/15 04:29 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
A-body with a strut front end.
Re: kaase 820ci mopar hemi [Re: GY3] #1748274
02/07/15 05:28 PM
02/07/15 05:28 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Well duh ?
It is obviously a Hemi 99 on steroids.
Re: kaase 820ci mopar hemi [Re: tubtar] #1748275
02/07/15 06:56 PM
02/07/15 06:56 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The Kaase "Mopar" Hemi, is a carbon copy of his "Ford" Hemi, with the exception of the spark plug locations. Go to the Kaase site, click on products, look at the chamber side shot of the FORD hemi, picture the spark plugs moved inside on the center cylinders and outside on the end cylinders and you have the MOPAR Hemi.............That's IT in a nutshell, and of course some cool MOPAR valve covers...........LOL!!
Same block, same head, same everything, other than the plug location. seen several of each at PDRA races
Monte
Re: kaase 820ci mopar hemi [Re: unknown] #1748276
02/07/15 08:07 PM
02/07/15 08:07 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I actually typed out: "besides the milled Mopar name on the valvecover.."
Re: kaase 820ci mopar hemi [Re: Monte_Smith] #1748277
02/07/15 08:12 PM
02/07/15 08:12 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
At that level it has no "brand". What is the bellhousing pattern/starter pattern? It's a 100% aftermarket Kaase engine that uses whatever is best.
Mopar to the bone!!!
Re: kaase 820ci mopar hemi [Re: Monte_Smith] #1748278
02/07/15 08:44 PM
02/07/15 08:44 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Monte
Monte your hatred for mopar is obvious.
It's says mopar on the cover it must be one.
Plus it's the new G3 going into the new srt ram. Matt
Re: kaase 820ci mopar hemi [Re: MattW] #1748279
02/07/15 09:36 PM
02/07/15 09:36 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No hatred from me whatsoever. Wish I had one, although don't know what I would do with it..........But from a "what is it point".....that motor is as much of a Mopar, as it is a Ford or a Chevy. The main answer being NONE. It is an aftermarket aluminum race engine. The only factory parts from ANYBODY that likely fit it, would probably be a BBC water pump and it has a GM trans pattern.
Now, let me pose you this question. If I show up with the above motor, at an "All Mopar" power event........can I run it, because it is advertised on Kaase site as a Mopar and says it on the valve covers. The answer is likely yes.........Now on the flip side, I build an all aluminum, aftermarket 5.0 bore space wedge motor and show up at same event, with Mopar scrawled on the covers.....they will run me off and holler "that's a Chevy motor"........THAT is my issue, with all this stuff. No consistency on what is and isn't
Monte
Re: kaase 820ci mopar hemi [Re: Monte_Smith] #1748280
02/07/15 09:45 PM
02/07/15 09:45 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
Who cares what it is or what it looks like, If I had the money that would be one sweet motor in a Cuda or Duster for the Midwest Mountain Motor Nostalgia Pro Stock Drag Racing.
Re: kaase 820ci mopar hemi [Re: unknown] #1748281
02/07/15 10:47 PM
02/07/15 10:47 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
If I win the Powerball, I'll be ordering one and then let Monte put a plate on it!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: kaase 820ci mopar hemi [Re: unknown] #1748282
02/07/15 11:27 PM
02/07/15 11:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Sorry, but it needs to go in this - cause I got the room.
Fastest 300
Re: kaase 820ci mopar hemi [Re: Crizila] #1748283
02/08/15 12:03 AM
02/08/15 12:03 AM
regardless of what it really is,the mopar faithfull have at least a glimmer of some competitive horsepower packaged in a more similar fashion than the other billet motors.yes its still a hybrid,but,it sure looks familiar in more ways than the others.even knowing thats a petty and silly comparison,apples to oranges,why not?its the largest mopar "style" mountain motor to date and everybody knows we all want one.....
Page 1 of 4 1 2 3 4
