kaase 820ci mopar hemi
#1748264
02/07/15 01:58 AM
02/07/15 01:58 AM
Posts: 515 geezer acres rest home
dakotawilly
for all the big dog mopar racers out there,kaase 820 cubic inch mopar hemi,5 x 12 billet block,1800 plus horsepower.call for price {sitting down of course}.....
SFI 25.5 depends,no leak,even at 213 mph....
Re: kaase 820ci mopar hemi
[Re: hemicop]
#1748268
02/07/15 01:58 PM
02/07/15 01:58 PM
Posts: 792 Earth
Rob C
Earth
YEAH!-------------- THAT'LLL fit in an A-body!
Sure will! Who's first?!!
[Re: Rob C]
#1748269
02/07/15 02:15 PM
02/07/15 02:15 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
I hope it runs on pump gas!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: GY3]
#1748272
02/07/15 03:32 PM
02/07/15 03:32 PM
Posts: 622 sing sing
unknown
sing sing
So what makes it a Mopar?
It says so on the valve cover,
[Re: hemicop]
#1748273
02/07/15 04:29 PM
02/07/15 04:29 PM
Posts: 964 Odessa, Fl
blowndart
Odessa, Fl
A-body with a strut front end.
[Re: GY3]
#1748274
02/07/15 05:28 PM
02/07/15 05:28 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Well duh ? It is obviously a Hemi 99 on steroids.
[Re: tubtar]
#1748275
02/07/15 06:56 PM
02/07/15 06:56 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The Kaase "Mopar" Hemi, is a carbon copy of his "Ford" Hemi, with the exception of the spark plug locations. Go to the Kaase site, click on products, look at the chamber side shot of the FORD hemi, picture the spark plugs moved inside on the center cylinders and outside on the end cylinders and you have the MOPAR Hemi.............That's IT in a nutshell, and of course some cool MOPAR valve covers...........LOL!!
Same block, same head, same everything, other than the plug location. seen several of each at PDRA races
Monte
[Re: unknown]
#1748276
02/07/15 08:07 PM
02/07/15 08:07 PM
Posts: 4,663 Wichita
GY3
Wichita
I actually typed out: "besides the milled Mopar name on the valvecover.."
[Re: Monte_Smith]
#1748277
02/07/15 08:12 PM
02/07/15 08:12 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
At that level it has no "brand". What is the bellhousing pattern/starter pattern? It's a 100% aftermarket Kaase engine that uses whatever is best.
Mopar to the bone!!!
[Re: Monte_Smith]
#1748278
02/07/15 08:44 PM
02/07/15 08:44 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Monte
Monte your hatred for mopar is obvious.
It's says mopar on the cover it must be one. Plus it's the new G3 going into the new srt ram. Matt
[Re: MattW]
#1748279
02/07/15 09:36 PM
02/07/15 09:36 PM
Monte_Smith
North Alabama
No hatred from me whatsoever. Wish I had one, although don't know what I would do with it..........But from a "what is it point".....that motor is as much of a Mopar, as it is a Ford or a Chevy. The main answer being NONE. It is an aftermarket aluminum race engine. The only factory parts from ANYBODY that likely fit it, would probably be a BBC water pump and it has a GM trans pattern.
Now, let me pose you this question. If I show up with the above motor, at an "All Mopar" power event........can I run it, because it is advertised on Kaase site as a Mopar and says it on the valve covers. The answer is likely yes.........Now on the flip side, I build an all aluminum, aftermarket 5.0 bore space wedge motor and show up at same event, with Mopar scrawled on the covers.....they will run me off and holler "that's a Chevy motor"........THAT is my issue, with all this stuff. No consistency on what is and isn't
Monte
[Re: unknown]
#1748281
02/07/15 10:47 PM
02/07/15 10:47 PM
Posts: 860 lancaster,california
johnnycuda
If I win the Powerball, I'll be ordering one and then let Monte put a plate on it!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Crizila]
#1748283
02/08/15 12:03 AM
02/08/15 12:03 AM
dakotawilly
regardless of what it really is,the mopar faithfull have at least a glimmer of some competitive horsepower packaged in a more similar fashion than the other billet motors.yes its still a hybrid,but,it sure looks familiar in more ways than the others.even knowing thats a petty and silly comparison,apples to oranges,why not?its the largest mopar "style" mountain motor to date and everybody knows we all want one.....
