Roller Cam button install question #174323
12/24/08 07:53 PM
12/24/08 07:53 PM
Usa
10secchallenger Offline OP
Usa
i have a 440 and this is the first time i have installed a roller cam.i have a comp cams cam,timing chain set,button.the problem i have is i installed the cam button in the cam gear(the black bushing first) then the nylon button.once the button is in i can't get a hex bolt or a allen head bolt in the cam gear. its almost as if the button is too big in diameter.anyone else run into this?any advice is greatly appreciated.
Re: Roller Cam button install question [Re: 10secchallenger] #174324
12/24/08 08:14 PM
12/24/08 08:14 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If I understand you right the 3 cam bolts interfere with the cam button.If this is the case you can either turn down your allen socket bolt heads,notch the button or get some grade 8 12 point bolts(small heads)
Re: Roller Cam button install question [Re: B G Racing] #174325
12/24/08 09:07 PM
12/24/08 09:07 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The 3/8 header bolts are great in this application with there reduced heads, even can be found with 3/8 wrench heads..They are usually a higher grade fastener also. Don'T forgot to add a little Blue locktite.
Re: Roller Cam button install question [Re: Bob_Coomer] #174326
12/24/08 09:13 PM
12/24/08 09:13 PM
Usa
Usa
hey thanks guys,yes this is a three bolt gear.i tried the header bolt also, but mine have 7/16 head on them and the little flange also hit the button. i guess i'll try to notch the button for the allen heads fit.you'd think that there would be some kind of info on this.
Re: Roller Cam button install question [Re: 10secchallenger] #174327
12/24/08 10:50 PM
12/24/08 10:50 PM
Don't forget to check end play once e=veything is in and tighten up, .003 to .010 should work okay usuaully. do you have the raer cam plug out still If not it makes reading the end play a little harder
Re: Roller Cam button install question [Re: Cab_Burge] #174328
12/24/08 11:18 PM
12/24/08 11:18 PM
AndyF Offline
AndyF  Offline
I provide an extra center section with my billet timing chain covers just for checking end play. With this cover you just bolt it all together and then slide a dial indicator into the slot and measure the end play directly.
As for the cam button issue, I've never found a cam button that works right off the shelf. I've tried them all and they all need a trip to the machine shop before they're correct.
Re: Roller Cam button install question [Re: AndyF] #174329
12/25/08 12:08 AM
12/25/08 12:08 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
How about this one?
I bolted mine on the other day just for a quick test fitting & it seemed to work fine...
BTW Your Timing cover is a work of art...
Re: Roller Cam button install question [Re: AndyF] #174330
12/25/08 01:19 AM
12/25/08 01:19 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Andy, the isky rollerized button fits fine w/out any machining; at least it did for me...........that`s why isky rules among many other reasons.
Re: Roller Cam button install question [Re: Thumperdart] #174331
12/25/08 01:55 AM
12/25/08 01:55 AM
If you are usihg a stock timing cover you will have to ding it out to get some clearance more than likely...
Re: Roller Cam button install question #174332
12/25/08 03:15 PM
12/25/08 03:15 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Andy, Give us the low down on that oil pump cover. I am sure you probably machined it. Everything you seem to post you have made, and it is always super nice. Beep
Re: Roller Cam button install question [Re: Bigbeep] #174333
12/25/08 08:08 PM
12/25/08 08:08 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Header bolts are a must and a cheep button (i use the crain gold) is EASY to fit.
I shoot for about .005 end play and use the stock cover that flex's slightly but it's never been a problem and it's cheep.
Re: Roller Cam button install question [Re: FastmOp] #174334
12/25/08 08:41 PM
12/25/08 08:41 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I use the Crane gold button, stock type chrome timing cover. There's a recessed hole in the back of my Mezeire water pump so I cut a piece of tubing that goes in that hole and butts up against the cover to keep it from flexing. Simple and cheap.
Re: Roller Cam button install question [Re: Bigbeep] #174335
12/25/08 10:13 PM
12/25/08 10:13 PM
AndyF Offline
AndyF  Offline
Thanks. Yes I did make that oil pump cover. It is designed to go straight to #12 lines for a remote filter. Nobody else makes anything like that so I had to design my own.
Re: Roller Cam button install question [Re: Thumperdart] #174336
12/31/08 12:04 AM
12/31/08 12:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Update:
My timing set arrived today, this style thrust bearing
won't work...My cam gear has recessed bolt holes so the flat plate that is part of the bearing interferes & won't allow the bolts to fit into the recessed areas...The fun nevers ends..
