Re: Roller Cam button install question
[Re: Bob_Coomer]
#174326
12/24/08 09:13 PM
12/24/08 09:13 PM
Posts: 601 Usa
10secchallenger
Usa
The 3/8 header bolts are great in this application with there reduced heads, even can be found with 3/8 wrench heads..They are usually a higher grade fastener also. Don'T forgot to add a little Blue locktite.
hey thanks guys,yes this is a three bolt gear.i tried the header bolt also, but mine have 7/16 head on them and the little flange also hit the button. i guess i'll try to notch the button for the allen heads fit.you'd think that there would be some kind of info on this.
[Re: Cab_Burge]
#174328
12/24/08 11:18 PM
12/24/08 11:18 PM
Posts: 30,945 Oregon
AndyF
I provide an extra center section with my billet timing chain covers just for checking end play. With this cover you just bolt it all together and then slide a dial indicator into the slot and measure the end play directly.
As for the cam button issue, I've never found a cam button that works right off the shelf. I've tried them all and they all need a trip to the machine shop before they're correct.
[Re: AndyF]
#174329
12/25/08 12:08 AM
12/25/08 12:08 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
How about this one? I bolted mine on the other day just for a quick test fitting & it seemed to work fine...
BTW Your Timing cover is a work of art...
[Re: Thumperdart]
#174331
12/25/08 01:55 AM
12/25/08 01:55 AM
If you are usihg a stock timing cover you will have to ding it out to get some clearance more than likely...
[Re: FastmOp]
#174334
12/25/08 08:41 PM
12/25/08 08:41 PM
Posts: 17,916 Akron, Ohio
ProSport
Akron, Ohio
I use the Crane gold button, stock type chrome timing cover. There's a recessed hole in the back of my Mezeire water pump so I cut a piece of tubing that goes in that hole and butts up against the cover to keep it from flexing. Simple and cheap.
[Re: Bigbeep]
#174335
12/25/08 10:13 PM
12/25/08 10:13 PM
AndyF
Andy, Give us the low down on that oil pump cover. I am sure you probably machined it. Everything you seem to post you have made, and it is always super nice. Beep
Thanks. Yes I did make that oil pump cover. It is designed to go straight to #12 lines for a remote filter. Nobody else makes anything like that so I had to design my own.
