TCS aluminum direct drum bushing #1742912
01/31/15 03:49 AM
01/31/15 03:49 AM
Sac, CA, USA
N
ntstlgl1970 Offline OP
N
Sac, CA, USA
I have a TCS steel jacket aluminum drum in my car and the bushing needs to be replaced. Anyone change one before? The stator sealing rings wore some serious grooves into the bushing - was using the transgo sealing rings (scarf cut teflon I think). Should I be using different sealing rings? I thought using the regular metal rings would tear the bushing up real bad.
Re: TCS aluminum direct drum bushing [Re: ntstlgl1970] #1742913
01/31/15 10:59 AM
01/31/15 10:59 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Steel rings are recommended on a non bushed aluminum drum. The Teflons are more aggressive.
Doug
Re: TCS aluminum direct drum bushing [Re: ntstlgl1970] #1742914
01/31/15 11:24 AM
01/31/15 11:24 AM
NC
440Jim Offline
440Jim  Offline
NC
I have the TCS aluminum drum with the bushing. After many years I replaced it due to sealing ring wear on the bushing. Tips I remember:
1) make a bushing driver to fit
2) use a little Loctite between the bushing and drum
3) align holes/slots in bushing with matching part of drum
Mine pressed out and back in without too much effort. But I used a well fitting bushing driver and a manual arbor press to push it straight.
Re: TCS aluminum direct drum bushing [Re: 440Jim] #1742915
01/31/15 12:23 PM
01/31/15 12:23 PM
BigFish69 Offline
BigFish69  Offline
I sent my back to TCS for 75.00 included bushing and labor not worth chance of tipping the bushing and distorting the aluminum housing if you don't have the proper tools.
Re: TCS aluminum direct drum bushing [Re: BigFish69] #1742916
02/04/15 05:35 AM
02/04/15 05:35 AM
Sac, CA, USA
N
N
Sac, CA, USA
going to talk to TCS tomorrow, was starting to have issues of clutch chatter in reverse when hot, but no issues with 3rd (this is in a 518). Guess I found the source of that issue
