I have a TCS steel jacket aluminum drum in my car and the bushing needs to be replaced. Anyone change one before? The stator sealing rings wore some serious grooves into the bushing - was using the transgo sealing rings (scarf cut teflon I think). Should I be using different sealing rings? I thought using the regular metal rings would tear the bushing up real bad.
