E-body Door jam switch ? #1740570
01/27/15 07:43 PM
01/27/15 07:43 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Ordered up a 2 pin switch for our 72 cuda from Classic. Thought ours was a 2 pin. Turns out the passenger side is a 2 pin but the drivers side is a 3 pin. Classic only offers the 2 and single pins. Our wiring is 2 yellows and 1 black wire. Was thinking can I put a spade on both yellows and one on the black and attach it like a 2 pin? The part number at Classic is SW90. My thought is its an open or shut switch so running the 2 yellows together would work. Any ideas? Anyone else run into that? Our old one was hashed and not really there.
corey
Contact Me about AMD Prices
Re: E-body Door jam switch ? [Re: hotairballoonpilot] #1740571
01/27/15 07:45 PM
01/27/15 07:45 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
71's used a three pin switch I think. Is it an early production 72?
Re: E-body Door jam switch ? [Re: hotairballoonpilot] #1740572
01/27/15 08:00 PM
01/27/15 08:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I built a 3 pin switch out of 2 or 3 switches to work in my 71 drivers door. I can't remember exactly but I got the switches from the local auto part store after hunting through catalogs.
It does not look stock but works.
Re: E-body Door jam switch ? [Re: hotairballoonpilot] #1740573
01/27/15 08:17 PM
01/27/15 08:17 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
You are going to have to consult the FSM. Some door switches go to ground, others switch all of the wires to each other and others do a combination. The factory used the unusual switch for a reason and just tieing them together could lead to back feeding power to other circuits with unwanted results. Kind of like the ground issues that have driven us crazy trying to figure them out.
I have a 72 FSM at home and will try to remember to look at it when I get home.
Craig
Re: E-body Door jam switch ? [Re: hotairballoonpilot] #1740574
01/27/15 08:39 PM
01/27/15 08:39 PM
NC
1970A66 Offline
1970A66  Offline
NC
Re: E-body Door jam switch ? [Re: 1970A66] #1740575
01/27/15 08:43 PM
01/27/15 08:43 PM
Cincinnati, Ohio
Cincinnati, Ohio
No the threads are too big I believe.
Re: E-body Door jam switch ? [Re: Challenger 1] #1740576
01/27/15 08:51 PM
01/27/15 08:51 PM
NC
1970A66 Offline
1970A66  Offline
NC
Are you sure, too big?
They are 3/8 threads which are the smallest ones.
Re: E-body Door jam switch ? [Re: denfireguy] #1740577
01/27/15 08:57 PM
01/27/15 08:57 PM
South Dakota
South Dakota
Craig
Thanks! Yeah I was worried on that back feeding issue in back of my mind.
As far as build date Not sure if its an early 72. Would guess if 71's used that style.
thanks guys!
Re: E-body Door jam switch ? [Re: 1970A66] #1740578
01/27/15 09:01 PM
01/27/15 09:01 PM
South Dakota
South Dakota
Is this this the one?
http://www.ebay.com/itm/70-71-72-73-74-D...R-/390917861532
Yes I believe thats what it should of looked like. Its 3 pins like the wire is.
Re: E-body Door jam switch ? [Re: hotairballoonpilot] #1740579
01/27/15 09:28 PM
01/27/15 09:28 PM
NC
1970A66 Offline
1970A66  Offline
NC
Here's a NOS jamb switch:
http://www.ebay.com/itm/400808128150?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Identical to that repo one.
They show the same OEM part #.
It's what you need.
Re: E-body Door jam switch ? [Re: burdar] #1740580
01/28/15 08:49 PM
01/28/15 08:49 PM
South Dakota
South Dakota
Talked to Jamie at Megaparts. He is contemplating buying a few NOS ones and getting them reproduced! Thats great to hear!
Re: E-body Door jam switch ? [Re: denfireguy] #1740581
01/30/15 12:47 PM
01/30/15 12:47 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Finally looked at the manual. All three go to ground. The black wire is the headlight on buzzer. One yellow is the dome light and the other yellow is for the time delay lights on the ignition switch and headlight switch as well as the map light. They all look like they would back feed to other circuits if tied together. If you have a two circuit switch, tie the black wire to one switch lug. On the other switch lug, hook two 1N4001 diodes non bar end. Hook the bar end of the diodes to each of the yellow wires. This will isolate them. You can buy a bag of diodes from Radio Shack cheap. Part no 276-1653.
Without the isolation, on my car anyway, the map light switch would blow the dome light fuse.
Craig
