E-body Door jam switch ?
#1740570
01/27/15 07:43 PM
01/27/15 07:43 PM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
Ordered up a 2 pin switch for our 72 cuda from Classic. Thought ours was a 2 pin. Turns out the passenger side is a 2 pin but the drivers side is a 3 pin. Classic only offers the 2 and single pins. Our wiring is 2 yellows and 1 black wire. Was thinking can I put a spade on both yellows and one on the black and attach it like a 2 pin? The part number at Classic is SW90. My thought is its an open or shut switch so running the 2 yellows together would work. Any ideas? Anyone else run into that? Our old one was hashed and not really there.
corey
Contact Me about AMD Prices
Re: E-body Door jam switch ?
[Re: hotairballoonpilot]
#1740573
01/27/15 08:17 PM
01/27/15 08:17 PM
Posts: 1,822 Colorado
denfireguy
Colorado
You are going to have to consult the FSM. Some door switches go to ground, others switch all of the wires to each other and others do a combination. The factory used the unusual switch for a reason and just tieing them together could lead to back feeding power to other circuits with unwanted results. Kind of like the ground issues that have driven us crazy trying to figure them out. I have a 72 FSM at home and will try to remember to look at it when I get home. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: burdar]
#1740580
01/28/15 08:49 PM
01/28/15 08:49 PM
hotairballoonpilot
South Dakota
Talked to Jamie at Megaparts. He is contemplating buying a few NOS ones and getting them reproduced! Thats great to hear!
[Re: denfireguy]
#1740581
01/30/15 12:47 PM
01/30/15 12:47 PM
denfireguy
Colorado
Finally looked at the manual. All three go to ground. The black wire is the headlight on buzzer. One yellow is the dome light and the other yellow is for the time delay lights on the ignition switch and headlight switch as well as the map light. They all look like they would back feed to other circuits if tied together. If you have a two circuit switch, tie the black wire to one switch lug. On the other switch lug, hook two 1N4001 diodes non bar end. Hook the bar end of the diodes to each of the yellow wires. This will isolate them. You can buy a bag of diodes from Radio Shack cheap. Part no 276-1653. Without the isolation, on my car anyway, the map light switch would blow the dome light fuse. Craig
