Re: back in the 9's [Re: Leigh] #1738335
01/26/15 06:48 PM
01/26/15 06:48 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Lots left in it for sure. Now if we can talk him into a good shifter
Re: back in the 9's [Re: J_BODY] #1738336
01/26/15 06:52 PM
01/26/15 06:52 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Between going full retard with a new combo
Just had to
Re: back in the 9's [Re: Al_Alguire] #1738337
01/26/15 06:57 PM
01/26/15 06:57 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
My SCS Cheetah does the same thing in the demon. I have a sign on the front bar that says "Hand off the shifter" so I do not get to 2nd right on the launch.
Nice passes.
Re: back in the 9's [Re: Airwoofer] #1738338
01/26/15 08:05 PM
01/26/15 08:05 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Nice passes.
I've got that 1st gear detent dang tight now. If you ever feel in the mood for improvement, drop your valve body, shim the spring behind the detent ball, and file that first gear slot a little deeper
Re: back in the 9's [Re: J_BODY] #1738339
01/26/15 09:49 PM
01/26/15 09:49 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
E68 engine pulled from an old highway patrol car with a 3/4 race cam......
...or it could be a R3 block 4" stroke 439 W8 combo. 264-272 @ .050 108lsa .750 lift at retainer, 13.5-1....750 cfm double pumper. should still creep into the 9's in Vegas. Needs a little more gear....4.30 in it right now.
Nice! What converter and how much does it weigh?
Man that is too cool running 9's with a worked 750 dp!
Re: back in the 9's [Re: moparmanjames] #1738340
01/26/15 10:16 PM
01/26/15 10:16 PM
Casper, WY
W
Wax Offline
Wax  Offline
W
Casper, WY
Buy the electric or CO2 shift kit for your current shifter. You can shift it with time or rpm. Just a thought cousin. I see that the car still pulls the front tires. It seems that it has always done that. See if you can borrow a BIG carb and put on for test and tune. It will haul the mail for sure.
Re: back in the 9's [Re: moparmanjames] #1738341
01/26/15 11:12 PM
01/26/15 11:12 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
the driveline was basically untouched from our W5 era. We have 2 converters from Ultimate and currently the 8" is in there. We also have a 9" that may actually be better suited to the torque of this thing. Got to get alot ironed out before we start playing with converters. I actually saw quite a bit more trans temp on these passes, but so far attributing that to the "automatic" shift at the hit. Dropping from 6200 rpm to 3500 will create some heat Car weighs just a bit under 3K with driver.
Re: back in the 9's [Re: J_BODY] #1738342
01/27/15 01:22 AM
01/27/15 01:22 AM
Las Vegas NV
Las Vegas NV
Yeah I hear ya on the ironing out, I barely have time to work on mine, I wanted to go test at this next Vegas race but I have to go to China of all places for 3 weeks so I'm aiming for MATS as my next outing.
Man your car is making some steam for sure, 141 mph is badass for the first outing, great job man.
What rpm is it going through at?
Re: back in the 9's [Re: J_BODY] #1738343
01/27/15 01:41 PM
01/27/15 01:41 PM
an8sec70cuda Offline
Congrats! Very strong running combo and a nice first trip to the track w/ it!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: back in the 9's [Re: J_BODY] #1738344
01/30/15 12:06 PM
01/30/15 12:06 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Congrats to you. I know it has got to be a great feeling to be back in the saddle.
Re: back in the 9's [Re: Rob C] #1738345
01/30/15 12:31 PM
01/30/15 12:31 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Great to hear you hit the track again with some VERY nice hits.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
