back in the 9's #1738315
01/25/15 02:54 PM
01/25/15 02:54 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
well I've had some inquiries as to how the car ran last week. Hauled down to Phoenix to partake in a chassis cert session and entered the test and tune. At this point I'll say the engine ran great.... however... Between going full retard with a new combo, and a shifter that decided it would make the 1-2 shift on the hit, we didn't get one real good pass out of the five. I'll condense the five passes into one time slip between flubbed shifts and tire spin:
1.28 60 best out of the 5 and best for the car. this shows hope. minimal wheel stand.
6.100 to the 1/8 on that hit... new best. 113.45 @ the 1/8.... another new best.
9.644 1/4 @ 141.12.
Guess that will be my baseline for things to come.
We dynoed the engine with a Quick Fuel 1050.... spacer and my dominator wouldn't clear the hood, so I grabbed the 4150 BG carb off the 360. Now we knew absolutely nothing about this carb other than a friend bought it at a swap meet ions ago (IIRC it was presented as a 930cfm) and we'd used time to time on different engines. It always worked well, as it did on this engine. But I finally did a little "learning" and came up with BG4779-3 with 1.68 throttle plates is basically a really good 750 cfm carb. Perfect for a small block....but probably not this one.
The shifter.... the love/hate of the T/A Cheetah SCS seems to run very deep on both sides. I've been told the "SCS" means Sometimes Continues Shifting.... I learned the difference between a "gate" shifter, and a "ratchet" shifter. I was ready to give PPP my hard earns, but after calling them and talking options my head was ready to explode so I sat back and weighed my options. I called TA and talked to Paul.... of course I'm the only one in the universe that has had this issue, but in talking with him I came to the realization that I might be able to work this out. I dropped my Griner valve body out friday night and to work we went. I removed the "rooster comb" and shimmed the detent spring. I also took a die grinder to the 1st gear detent and after about 3 hits of increasing it's depth and steepening the ramp I could hardly shift it on the bench by hand. Installed it in the car and BANG! I can now feel 1st and it won't drift back into 2nd, but yet shifts firm. Might have saved myself a little coin with a die grinder/beer session. I probably should have done the same to the 2nd detent, but the gate on the shifter seems to work fine for 2-3.
Only other "big" issue of note was that when I had to really lean on the brakes toward the end of the shutdown on the 1/4 passes was that the oil psi dropped. We added a quart for the last hit and it didn't seem to make alot of difference. That might take some thinking.... Easy button might be a clean N valve body
I've got alot to learn, changes to be made, but realistically I think we'll get 147mph out of it. Maybe not in Vegas, but I think it's there.
and HUGE THANKS to: Brett Miller (top end), Brian Hafliger (IMM Engines), Brian Smith (Smith Innovations), Comp Chassis in Phoenix, and Al Alguire who's always a text away!
Re: back in the 9's [Re: J_BODY] #1738316
01/25/15 03:02 PM
01/25/15 03:02 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
69 GTX 68 Road Runner
Re: back in the 9's [Re: J_BODY] #1738317
01/25/15 03:03 PM
01/25/15 03:03 PM
BPE Offline
BPE  Offline
Sounds like a good first outing.Things never seem to go as planned, but it sounds like you have a handle on it.
Rod
Re: back in the 9's [Re: J_BODY] #1738318
01/25/15 03:15 PM
01/25/15 03:15 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Good 60',good top end mph better then Mine..1/8 is the same As mine...kinda weird.
One thing I've known and believe is our little sb's love carburetion for some reason.
Good luck...
Re: back in the 9's [Re: J_BODY] #1738319
01/25/15 03:15 PM
01/25/15 03:15 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
I still prefer my B&M Pro Stick. Simple and effective
Re: back in the 9's [Re: J_BODY] #1738320
01/25/15 03:53 PM
01/25/15 03:53 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
anytime they're still in one piece is a good thing.. I'm sure there's a lot more to come ..good luck
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: back in the 9's [Re: J_BODY] #1738321
01/25/15 04:40 PM
01/25/15 04:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The oil pressure drop under deceleration is not a good thing... maybe time for an Accusump?
Re: back in the 9's [Re: J_BODY] #1738322
01/25/15 04:47 PM
01/25/15 04:47 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Jay I'm sure as the bugs are worked out of your new combo you will be smiling more when you get your time slip.
"Just a Bracket car dressed up like a streetcar"
Re: back in the 9's [Re: Just-a-dart] #1738323
01/25/15 06:17 PM
01/25/15 06:17 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Not a bad day at the office at all.
I am a couple snow falls away from my first hits on the track , so I am encouraged by your success.......and now have a list of potential mistakes I will make too.
Well done.
I went with an accu-sump for a couple reasons , one of them being extended highway cruising.
I was a little worried about oil staying upstairs and sucking the pan dry on the long stretches where my right foot fails to retract , as well as losing pressure in the shut down , but the needle stays where Daddy likes it with that deal.
Re: back in the 9's [Re: tubtar] #1738324
01/25/15 06:25 PM
01/25/15 06:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Are we going to see you and the car in Vegas?
Feb 14 & 15?
Tony
70 AARCuda Vitamin C
Re: back in the 9's [Re: fishy340] #1738325
01/25/15 06:49 PM
01/25/15 06:49 PM
Out West
408strokerdart Offline
Out West
Good luck...
I know mine loves the 1250 even with the little camshaft.
Re: back in the 9's [Re: 408strokerdart] #1738326
01/25/15 07:19 PM
01/25/15 07:19 PM
SoCal
Brian Hafliger Offline
SoCal
Yeah I'm pretty sure it's gonna pick up quite a bit with a larger carb.
Brian Hafliger
Re: back in the 9's [Re: J_BODY] #1738327
01/25/15 08:47 PM
01/25/15 08:47 PM
Hmm, the trans shifts itself into 2nd at the hit on the starting line, I never had that happen AFTER I learned to stiffen my arm up a bunch before hitting the throttle so my hand and arm wouldn't move backwards at the hit making the shifter shift Your not the first and I'm sure you will not be the last one to have that happen on a shifter like those in a car that moves really hard. I've even hurt my hand on my old 1963 Bracket Beleveder(1.49 60 ft.) when my hand flew off the shifter and hit the roof roll bar behind the seat Now to work on getting it to hook, BTW, how many times did your back hurt on the hit I had to retrain myself to push myself back into the seat before letting go of the button on the new car to make the stupid car quit hurtng my back during the run, especially last year when coming off the throttle stop
Re: back in the 9's [Re: Cab_Burge] #1738328
01/25/15 11:23 PM
01/25/15 11:23 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Its time to think about Quick 16 at MATs
Re: back in the 9's [Re: Jeepmon] #1738329
01/25/15 11:25 PM
01/25/15 11:25 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
This is the 1.28 60ft pass.
Re: back in the 9's [Re: Cab_Burge] #1738330
01/25/15 11:39 PM
01/25/15 11:39 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
I think that's what Jesse runs in his Duster. We had that conversation. Funny thing is I ran a Hurst Promatic 2 in my Mirada forever (ratchet shifter) and it never missed a beat. We order the same shifter for the Duster and had nothing but grief, so my dad ended up getting the TA. Pretty sure I've got a handle on this issue
no not a "happy" thing to have and issue with. Usually time consuming and expensive. Accumsump is a thought as is a clean N transbrake so I can just shut down the engine.... or pull the engine and re-evaluate what we have. Vegas has a pretty long shutdown as does Bakersfield so one of those tracks will be a true test.
it can only get better we hope! signed up for March Meet so I hope to have it somewhat ironed out for that.
Feb 14 & 15?
probably not Tony.... family flying into town and they always love to drag the locals down to the strip....
I kid you not.... on the fifth pass i let go of the trans brake and was watching/staring at the shifter shift on it's own. Not the safest thing in the world but that's why they have walls
If they limit entrys to blue small block A bodys I'm in!
Re: back in the 9's [Re: J_BODY] #1738331
01/26/15 12:26 AM
01/26/15 12:26 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's why I've ran the B&M Pro-Ratchet my whole life, bolt it in and forget about it, impossible to miss a shift.
Congrats on the first outing, that thing is fast!
Re: back in the 9's [Re: ProSport] #1738332
01/26/15 01:02 AM
01/26/15 01:02 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Dang J, that thing is flying! I know it's probably been covered but can you give a rundown of the combo? Awesome car man!
Re: back in the 9's [Re: moparmanjames] #1738333
01/26/15 11:42 AM
01/26/15 11:42 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
E68 engine pulled from an old highway patrol car with a 3/4 race cam......
...or it could be a R3 block 4" stroke 439 W8 combo. 264-272 @ .050 108lsa .750 lift at retainer, 13.5-1....750 cfm double pumper. should still creep into the 9's in Vegas. Needs a little more gear....4.30 in it right now.
Re: back in the 9's [Re: J_BODY] #1738334
01/26/15 06:28 PM
01/26/15 06:28 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Good to hear you got the car out! Runs strong
